Calculating Electric Field in a Line of Charge Problem
  • Thread starter Thread starter Andrew.
    Charge Line
The problem involves calculating the electric field at a specific radial distance from a wire located between two long concentric cylinders with equal and opposite charges per unit length. The subject area pertains to electrostatics and the application of Gauss's law.
  • Participants discuss the relevance of the cylinders' charges and their effect on the electric field, with one participant initially ignoring the cylinders based on an incorrect assumption. There is also a focus on the correct application of formulas related to electric fields and the determination of linear charge density.
Some participants have provided insights regarding the application of Gauss's law and the conditions under which the cylinders do not contribute to the electric field in the region of interest. There is an ongoing exploration of the correct values to use for calculations, particularly concerning the linear charge density.
Participants are navigating the complexities of the problem, including uncertainties about the charge values and the implications of the setup on the electric field calculation. The original poster expresses confusion about the calculations and assumptions made regarding the cylinders and wire.
Andrew.
There lies a section through 2 long concentric cylinders of radii 4.5 and 8 cm. The cylinders have equal and opposite charges per unit length of 2 C/m. Along the common axis runs a wire with an equal positive charge per unit length. Find E at a radial distance r = 0.3 cm.
I'm not exactly sure how to complete this problem. I've calculated it ignoring the cylinders, thinking that their charges cancel each other out, yet this was still the incorrect answer. I've also tried this by adding up all of the forces from the cylinders at the point .3 cm, but yet this still didn't work! Any help would be greatly appreciated.
By Gauss's law, the cylinders will not produce any electrical field in the region inside the cylinders, regardless of the charges on the cylinders - equal, equal and opposite, different, whatever.
So you were right to ignore the cylinders (although for the wrong reason). Now the question is, how did you try to calculate the field?
I used the equation E = lambda / (2 * pi * epsilonknot * r)
With epsilonknot = 8.85 * 10^-12, and r = .003m
When I used it, however, I wasn't sure what value to use for lambda, the linear charge density, so I think the problem may lie in there.
Thank you very much, by the way. :)
The way I read it the charge on the wire is 2C/m, isn't it?
That gives a field of 1.2 x 1013N/C. Is that not the answer?
Ahh, I got it now! It turns out that that is indeed the answer. Thank you so very much! :)
  • · Replies 68 ·
9K
