How Can I Dimension an Electromagnet for Maximum Strength?
The discussion centers around the design and dimensioning of a large electromagnet for maximum strength. Participants explore various aspects including formulas, materials, and configurations, while addressing the challenges of heat management and magnetic field strength.
  • One participant seeks formulas to calculate the dimensions and electrical requirements for a large electromagnet, specifying a desired magnetic contact area and strength.
  • Another participant explains the basic construction of an electromagnet, emphasizing the importance of wire type and current management to avoid overheating.
  • A participant notes the need for precise calculations regarding core dimensions, wire turns, and the magnetic field strength, indicating that the electromagnet will operate in short cycles.
  • Concerns are raised about the potential for wire melting if operated continuously for 30 seconds, suggesting the use of magnet wire for better insulation.
  • A formula for calculating the magnetic field strength based on the number of turns, current, and permeability is provided, although no further context is given.
  • One participant shares a historical example of a small yet powerful magnet, suggesting that size does not always correlate with strength.
  • The original poster expresses a need for both a large magnetic contact area and a strong attraction field, asking for advice on the best design approach, such as using a solenoid or U-shaped magnets.
  • A later post indicates that the original poster has concluded the project is not feasible, suggesting a shift in their perspective on the problem.
Participants express various viewpoints on the design and feasibility of a large electromagnet, with no consensus reached on the best approach or specific formulas. The discussion remains unresolved regarding the optimal configuration and materials.
Participants mention the importance of managing heat production and the relationship between size and magnetic strength, but do not provide definitive solutions or assumptions regarding the calculations needed.
Individuals interested in electromagnet design, electrical engineering, and those exploring practical applications of magnetism may find this discussion relevant.
Coster
Hi,
I like to research the possibility to build an electromagnet that is quit big and has a lot of strength. As I really don't know much about magnetism, I don't see how to start with this.
Anyone that please can help me with some formulas?
I like to make a sort of excel or MATLAB program where I can put in some numbers
  • magnetic contact area
  • desired magnetic strength
So the program gives me how big my electromagnet should be and of course how much electricity it takes per sec.
Thx
brief explanation
an electromagnet is a collection of a very large amount of wire wrapped around a hunk of metal. (cunductable) eg. a nail. you wrap this wire around this nail (using magnet wire because it has a very thin insulation layer) then you need to consitder the size of the wire, and how much current you can pass through it WITHOUT MELTING IT! you can pour current through it but you have to keep it at a reasonable tempearature. even if this includes submerging it in liquid nitrogen, etc...
i don't have any specks on a electromagent but i do know that with the desired direction, there is ither a positive charge or a negitive charge.
one method is to make a coil with your fist and stick you thumb out the side.
thx for your reply.
The fact that I was asking this question on this forum is because I can't affort to use the trial and error method as I will build a large electromagnet.
The dimensions should go up to a cross-section of 40*40 cm^2 (15.75 *15.75 inches^2) or even up to 100*100 cm^2 (=39.4*39.4 inches^2). Cross section will probably be circular, as this is the most easiest, I guess.
This magnet will therefore require a lot of material.
Electrical power is not of that importance (at least not yet) as I can use a 125A (cos phi : 3) connection.
The magnet itself should run for short cycles only, some 10 to 30 seconds. So I guess heat production will be controlleable.
Therefore I like first to calculate my magnet into the smallest details (dimension of core, number of layers and turns of wires, the used current but most important of course the created magnetic attraction field and how deep it is working)
I hope someone can give me some formulas (with some explanation how to use) where I can start with.
Thx a lot!
i don't know any equations, but i know what you mean by a very large electromagnet.
by the way, 30 secconds could melt your wire significantly so you must be carefull
USE MAGNET WIRE! you can pile wire much higher (more revolutions) with magnet wire. because it is dipped in a insulator, not "surrounded" like normal wire.
i don't have equations, i suggest you look on google or something. I am sure its out there somewhere. good idea posting it.
Magnetic field = (number of turns of solenoid) * Current * permeability / (pi*diameter of turn)
MKS dimensions
Keep in mind that a magnet does not have to be large to be powerful. Back when I was a kid, Edmund Scientific Company (which later became EftonScience) sold a unit that was about 2 inches in diameter by an inch high. It ran on 2 'D' cell batteries, and could lift 500 pounds.
thx for your replies!
I know the dimension aren't related linear with the strengt, but I need really both : big magnetic contact area and a big attraction field.
I need 2 N/mm^2 (145 pounds force / sq.inch ) at a few mm (+/- 0.1inches) of the magnetic area.
If I will make this magnetic contact area, what should I do as best :
  • make a solenoid with soft iron core
  • place several U shaped magnets under a plate (in roset form)
  • other possibility...
@ moderator :
this thread can be closed. I examined my problem and I have found that it isn't feasible.
But anyway : thanks to everyone that has replied!
  • · Replies 42 ·
  • · Replies 43 ·
