Solving for v_1, v_2, and v_3 with Nodal Analysis
The discussion focuses on solving for voltages v_1, v_2, and v_3 in a circuit using nodal analysis. The user derived equations based on Kirchhoff's Voltage Law (KVL) and Kirchhoff's Current Law (KCL), resulting in a matrix representation. The initial matrix indicated infinite solutions, but by eliminating the current variable I, a unique solution was found. The final calculated values are v_1 = 3.043 V, v_2 = -6.956 V, and v_3 = 0.6522 V.
  • Nodal analysis in electrical circuits
  • Understanding of Kirchhoff's Voltage Law (KVL)
  • Understanding of Kirchhoff's Current Law (KCL)
  • Matrix operations and Reduced Row Echelon Form (RREF)
  • Study advanced nodal analysis techniques
  • Learn about circuit simulation tools like LTspice
  • Explore the implications of infinite solutions in circuit analysis
  • Investigate the application of RREF in solving linear equations
Electrical engineering students, circuit designers, and professionals involved in circuit analysis and design will benefit from this discussion.
VinnyCee
Find v_1,\,v_2,\,and\,v_3 in the circuit below using nodal analysis:
My work so far:
I\,=\,\frac{v_1}{2\Omega},\,\,I_1\,=\,\frac{v_2}{4\Omega},\,\,I_2\,=\,\frac{v_3}{3\Omega},\,\,I_3\,=\,\frac{v_1\,-\,v_3}{6\Omega}
KVL @ loop1 => -I\,(2\Omega)\,+\,10\,V\,+\,I_1(4\Omega)\,=\,0
Which equals:
-\left(\frac{v_1}{2\Omega}\right)(2\Omega)\,+\,10\,V\,+\,\left(\frac{v_2}{4\Omega}\right)(4\Omega)\,=\,0
Which equals:
-v_1\,+\,10\,V\,+\,v_2\,=\,0
KVL @ loop2 => -v_2\,-\,5\,I\,+\,v_3\,=\,0
KVL @ loop3 => -10\,V\,+\,v_1\,-\,v_3\,+\,5\,I\,=\,0
KCL @ v1 => I\,+\,I_3\,+\,I_4\,=\,0
KCL @ v2 => I_4\,=\,I_1\,+\,I_5
KCL @ v3 => I_2\,=\,I_5\,+\,I_3
KCL @ Super Node 1 => I_4\,+\,I_3\,=\,I_1\,+\,I_2
When I combine these equations to get 4 equations with 4 variables, I get the following matrix:
\left[\begin{array}{cccc|c}<br /> -1 &amp; 1 &amp; 0 &amp; 0 &amp; -10 \\<br /> 0 &amp; -1 &amp; 1 &amp; -5 &amp; 0 \\<br /> 1 &amp; 0 &amp; -1 &amp; 5 &amp; 10 \\<br /> \frac{1}{2} &amp; \frac{1}{4} &amp; \frac{1}{3} &amp; 0 &amp; 0<br /> \end{array}\right]
The columns go like this: v1, v2, v3, I, constant
But this matrix has infinite solutions! How do I solve?
I figured it out!
The last variable column of the matrix can be eliminated because I\,=\,\frac{v_1}{2\Omega}
This gives the matrix:
\left[\begin{array}{ccc|c}-1 &amp; 1 &amp; 0 &amp; -10 \\-\frac{5}{2} &amp; -1 &amp; 1 &amp; 0 \\ \frac{7}{2} &amp; 0 &amp; -1 &amp; 10 \\ \frac{1}{2} &amp; \frac{1}{4} &amp; \frac{1}{3} &amp; 0 \end{array}\right]
This RREF's out to:
v_1\,=\,\frac{70}{23}\,=\,3.043\,V
v_2\,=\,-\frac{160}{23}\,=\,-6.956\,V
v_3\,=\,\frac{15}{23}\,=\,0.6522\,V\,V
NOTE: The third row of the matrix is not required!
