How Do I Calculate Probability Amplitudes for a Perturbed Quantum State?
  • Thread starter Thread starter Jumbuck
    Qm State Vectors
The original poster is working on a problem involving a harmonic oscillator system prepared in a specific quantum state and subjected to a perturbation. The task involves calculating probability amplitudes related to the perturbation expressed in terms of outer products of state vectors.
  • Participants discuss the manipulation of outer products of state vectors and the implications of orthogonality in quantum states. The original poster expresses uncertainty about the algebraic manipulation of these products and seeks hints or resources for better understanding.
Some participants have provided guidance on manipulating the algebra involved with state vectors, while others have clarified the formatting for LaTeX in the forum. The discussion is ongoing, with various interpretations of the mathematical expressions being explored.
The original poster notes a background in engineering, which may contribute to their uncertainty regarding the quantum mechanics concepts being discussed. There is also mention of potential confusion regarding the orthogonality of state vectors as referenced in the textbooks.
Jumbuck
For my homework, I have a problem in which a (harmonic oscillator) system is prepared in state n=2 for t<0.
For time t>0, there is a perturbation given by
V(t) = sqrt(3/4)*h_bar*omega* (|2><1| + |1><2|)
After this I need to compute the probability amplitudes. However, my background is in engineering, so I'm unsure how to work with these outer products of two state vectors, or even how this mixing works. If anyone has any hints or links on how to work with these, I would appreciate it very much.
Also, for future reference, do these forums automatically generate LaTeX, or do you import the LaTeX equations I've seen in other posts?
In these forums, you can get the $ ... $ environment by using the [ itex ] ... [ /itex] tags. And you can get the \[ ... \] environment with the [ tex ] ... [ /tex ] tags. (Remove the spaces to use those tags) (note the direction of the slash)
As to doing the algebra, just manipulate it formally. If you were faced with the product of |1><2| with |2>, that's given by |1><2|2> = |1>. Just remember that the distributive rules work (i.e. (A+B)C = AC + BC), but the commutative rule only works for scalars (i.e. for most S and T: [itex]ST \neq TS[/itex], but rS = Sr)
Thanks!
Since these are state vectors, would
(|2><1| + |1><2|) * |2>) = |2><1|2> + |1><2|2> = |1> ?
I believe these state vectors are orthogonal, so the <1|2> term is 0, but my textbooks isn't very clear.
Here's a useful little calculation: suppose that v and w are eigenstates of a hermetian operator T, with different associated eigenvalues. Then, compute:
[tex]\langle v | T | w \rangle[/tex]
and
[tex]\langle w | T | v \rangle[/tex]
Since these two expressions are complex conjugates of each other, it tells you something about [itex]\langle v | w \rangle = \langle w | v \rangle^*[/itex].
