Solving A = (B + C) / D - Isolate for C
  • Thread starter Thread starter Dazed
The discussion revolves around isolating the variable C in the equation A = (B + C) / D. Participants are examining the algebraic manipulation required to achieve this goal.
  • The original poster attempts to isolate C by multiplying both sides of the equation by D and then subtracting B. Other participants affirm this approach and discuss the importance of using parentheses in calculations.
Participants mention the importance of proper notation and parentheses when performing calculations, indicating a potential area of concern for accuracy in longer expressions.
Dazed
Does anybody see a problem with this?
Isolate for the variable given. Show all of your work.
A = (B + C) / D
isolate for C
A = (B + C) / D
A * D = B + C
C = A * D – B
Thanks for your help.. :)
Why that looks perfect.
Not trying to be stupid, but never forget to use the proper () if you put it in a calculator when it gets longer than this. It can drastically effect your answer. I found out the hard way a while ago... Just a heads up
Yeah, more than likely what steve said is your problem.
Multiply each side by D, and subtract by B will always give you the correct equation for C if this is the previous formula..
  • · Replies 24 ·
  • · Replies 40 ·
