Raindrop Physics: Solving for Terminal Speed of Falling Drop
  • Thread starter Thread starter S0C0M988
    Physics
The discussion revolves around the physics of a raindrop falling under gravity, specifically focusing on how its mass increases over time and how this affects its terminal speed. The problem presents a differential equation relating the rate of mass gain to the drop's velocity, while neglecting air resistance.
  • Participants are exploring the implications of the mass gain equation and questioning the assumptions about how the raindrop acquires mass. Some suggest considering the nature of collisions with other droplets, while others express uncertainty about how to begin setting up the problem.
There is an ongoing exploration of the problem's setup, with some participants offering insights into momentum conservation and the implications of different mass acquisition scenarios. No consensus has been reached, and various interpretations of the problem are being discussed.
Participants note that the wording of the problem may lead to confusion regarding the physical assumptions, particularly about the source of the additional mass and the nature of the interactions involved.
S0C0M988
A raindrop of initial mass Mo starts falling from rest under the influence of gravity. Assume that the drop gains mass at a rate proportional to the product of its instantaneous mass and its instantaneous velocity:
dM/dt = kMV
where k is a constant. Show that the speed of the drop eventually becomes effectively constant, and give an expression for the terminal speed. Neglect air resistance.
dM/dt = kMV
This is a poorly worded problem. Mass does not suddenly appear out of nowhere. The resulting motion depends on how the drop is acquring the mass. If it is simply condensing other tiny drops that are moving along with it, that is a completely different situation than if it is running into tiny drops that are at rest. I believe the problem is intended to be treated as the raindrop acquiring additional mass from tiny drops that may be considered at rest until bombarded by the larger drop.
Momentum is conserved in every collision. In this problem things are sticking togeter. See what you can do to set up the problem.
I have no idea how to even start to set up this problem.
If a raindrop of mass M moving with speed V runs into a bit of water of mass dM, initially at rest, and the two things stick together, how fast will they be moving after the collision assuming no other forces are acting?
It may be that your text is expecting you to assume the validity of the idea that
F = dp/dt = d(MV)/dt with M and V both function of time and do a relatively simple calculus problem. It is a much simpler approach than resorting to momentum conservation fundamentals, but as I stated earlier the assumptions make a difference. You can do the simple calculus problem and hope it is justified, or the more complete problem and justify the result. Choose your approach.
12K
