Can I test for Halides/Halogens cheaply and determine the concentration?
  • Thread starter Thread starter wxrocks
    Test
The discussion centers on methods for testing halides/halogens, particularly focusing on inexpensive techniques for determining their presence and concentration. Participants also explore the potential impact of ethylene dichloride on halogen test results and calculations related to achieving specific concentrations in water.
  • Some participants suggest using mass spectrometry for testing Cl and Br, noting that quantitative analysis would be more complex and require standardized concentration curves.
  • There is mention of using NMR to detect ethylene dichloride as a contaminant, which could also provide concentration estimates.
  • One participant calculates the necessary amount of ethylene dichloride to achieve a concentration of 25,000 ppm in a barrel of water, detailing the steps and assumptions involved in their calculations.
  • Another participant proposes gravimetric analysis with AgNO3 for chloride testing, explaining that the precipitate can be weighed to determine chloride content indirectly.
  • Electrochemical methods are also suggested as a quick way to determine halogen content, particularly for chloride.
  • Some participants express uncertainty about the calculations and seek confirmation on their reasoning regarding the amounts needed for specific concentrations.
Participants generally agree on the potential methods for testing halides/halogens, but there is no consensus on the best approach or the specifics of the calculations related to ethylene dichloride concentrations.
The discussion includes various assumptions about the purity of solutions and the conditions under which tests are conducted, which may affect the outcomes. Some calculations depend on specific definitions and conditions that are not fully resolved.
wxrocks
Is there an inexpensive way to test for Halides/Halogens and put a rough quantity/concentration on the content?
Second, could Ethylene Dichloride cause a halogen test to come up positive? If so, what kind of amounts to produce 1ppm in a gallon of water would be needed?
Thanks!
Chemistry news on Phys.org
Thanks!
you can test very easily for Cl and Br by using mass spec. (this depends if the mw of your compound is in the mass range for your instrument though). quantitative analysis would be harder. you would have to make standardized concentration curves probably, it is a pain. if ethylene dichloride is a contaminant in your product, it should show up on the NMR, which would also give you a handle on how much is in there as well. 1 L of water is 55.5 moles of H20. so if you had 1 ethylene dichloride molecule per 1million h20 (ok it is 1 in 999,999 but just use 1 million to make calculations easier, it won't be off by that much) molecules, you should be able to figure out easily how many molecules of ethylene dichloride are in 1 gallon of water with a concentration of 1ppm of ethylene dichloride.
Let me see if I am getting my calculations right ---
If I scale up to a barrel -- about 208 L -- I should have about 11544 moles of H2O. Now, if I want to obtain a 25,000 ppm of eth. dichl., I would want a ratio of 25k molecules of eth dichl./974,000 molecules water. multiply that ratio back by 11544 and I get 296 moles of eth. dichl. I should need for my concentration.
The molar density of eth. dicl is about 99 g/mol. so 296*99 = 29304 g total eth dichl I need. With a denisty of 1.253 g/cm3, I get roughly 23 Liters of Eth. dichl. per barrel of water to get a concentration of 25,000.
Sound reasonable??
Sound reasonable??
looks good
Thanks!
Quantitative analysis for some halides involve gravimetric analysis, for instance with Cl-, one can add AgNO3 to form AgCl (assuming that the solution isn't severely contaminated) and this precipitate can be dried, then weighed. The chloride content can be calculated indirectly through knowledge of the stoichiometric aspects of the experiment.
Another quick way to determine the chloride, or halogen content, is through electrochemical methods. Chloride, in particular, is a common agent in electrochemistry; e.g. AgCl reference electrode.
If you wanted to analyze ethelene dichloride, you would probably need to employ some standard organic chemical methods or use relatively more advanced chemical instrumentation/methods.
  • · Replies 19 ·
11K
  • · Replies 79 ·
15K
  • · Replies 21 ·
