Understanding Electric Current and Capacitance: Tips and Examples for Success
  • Thread starter Thread starter nautica
The discussion revolves around concepts of electric current, capacitance, and electric fields. Participants explore various problems related to these topics, including calculations involving potential difference, charge in capacitors, and the interpretation of units related to electric current and energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants attempt to solve problems involving current, potential difference, and capacitance, while also questioning the relationships between charge, voltage, and energy. Some express confusion over the definitions and units of electric field and charge.
The discussion includes attempts to clarify misunderstandings about the relationships between different electrical concepts. Some participants provide guidance on specific problems, while others express uncertainty about their interpretations and calculations. Multiple viewpoints on the questions are being explored, particularly regarding the units of measurement and the behavior of capacitors in series.
There are indications of confusion regarding the definitions of terms such as "coulomb" and "ampere-hour," as well as the application of formulas for electric fields and capacitance. Participants are also addressing potential errors in the problem statements and calculations.
nautica
1) A current of .5 A exist on a 60-ohm lamp. Find Potential Difference
Answer - 30 V
2) The sum of currents into a junction equals the sum of the currents out of the junction.
D)convservation of energy
E) Conservation of charge My answer is E
3)Current is a measure of:
D) amount of charge that moves past a point per unit time
E) speed with which a charge moves past a point
My answer is D
4) A 2uF and a 1uF capacitor are connected in a series and a potential difference is applied across the combination. The 2uF capacitor has:
a) twice the charge of the 1uF
b) half the charge of the 1uF
c) twice the potential difference of the 1uF
d) half the potential difference of the 1uF
e) none of the above
C=q/v so I picked A
5) the units of the electric field are
a) J/(C*m)
b) J/C
c) J*C
d) J/m
e) none of these
I know that electric field is N/C, But, I am think that would be the same as J/(C*m) So I say if not A then E
6) The electric field at a distance of 10 cm from an isolated point charge of (2x10^9 C) is: I can't even find a formula for this one.
7) A car battery is rated at 80 A * h is a unit of:
a) power
b) energy
c) current
d) charge
e) force
My ansswer is A) power
8) The capacitance of a parrallel-plate capacitor can be increase by:
A) increasing the charge
b) decreasing the charge
c) increasing the plate separation
d) decreasing the plate separation
e) decreasing the plate area
C=E A/d So I assume that if you decrease distance you will in crease capacitance. So d) decreast the plate separation.
Thanks
Nautica
For Pro 4: Charges will remain constant as capacitors are connected in series (**Look & Solve it Again**)
For Pro 5u have
energy =1/2 CV2
also Q=CV=CEd from above to eqn it seems A is correct if C is used for Capacitance
For Pro 6
electric field dur to a point charge is
[tex]=\frac{Q}{4\pi \epsilon_0 R^2}[/tex]
radially Outwards for + charge and inwards for - charge
Rest are correct
Number 7 is wrong. The amp-hour is a unit of charge. When multiplied by the potential created by the battery, you get energy.
- Warren
Thanks
C=q/v so if "charges remain constant", then then answer is D
a) J/(C*m) Joules/(Coulomb times meters)
b) J/C
c) J*C
d) J/m
e) none of these
The C is for Coulomb not capacitance, so is electric field is N/C then I can divide by m which convert the Newton to a Joule and multiply the coulomb by a meter, which would be A - right?
The Q/(4pieER^2)is what was think but there is no value for E. The choices are as follows:
a) 1.8 N/C
b) 180 N/C
c) 18 N/C
d) 1800 N/C
e) none of the above.
a) power
b) energy
c) current
d) charge
e) force
Okay, you said the answer for this one is energy. I am still a little confused. Coulomb is a Force. and Amp is 1 coulomb/sec to if we multply this by time (s) then it would be Force/s^2. which to me would be similar to a Watt, which is a measure of Power.?
Once again, thanks for the help
Nautica
Originally posted by nautica
The C is for Coulomb not capacitance... which would be A - right?
Right.
No values for E? The electric field, E, is measured in units of N/C. Hint: I think the question asked for 2*10^-9 C, NOT 2*10^9 C.
7) A car battery is rated at 80... Okay, you said the answer for this one is energy.
No, I quite clearly said the ampere-hour is a unit of charge.
No, it's not. The coulomb is a unit of charge.
- Warren
Q/(4pieER^2)
Why there is E in the denominator of the equation.
An Electric force is given by coulombs Law not by Coulomb(Unit of Charge)
  • · Replies 16 ·
  • · Replies 18 ·
