Deriving Electric Field for a Conductor-Shell System using Gauss's Law
  • Thread starter Thread starter chillaxin
    Gauss's law Law
The discussion focuses on deriving the electric field for a conductor-shell system using Gauss's Law. A long straight conducting rod with a linear charge density of +2.0 µC/m is enclosed by a thin cylindrical shell with a linear charge density of -2.0 µC/m. The electric field inside the shell is calculated using the formula E = q/(4πε₀r²), resulting in E = 4.5 x 10⁹ N·m²/C. The application of Gauss's Law, specifically the integral form ∮ E·dA = Q_encl/ε₀, is emphasized for determining the electric field both inside and outside the cylindrical shell.
  • Understanding of Gauss's Law and its mathematical formulation
  • Familiarity with electric fields and charge density concepts
  • Knowledge of cylindrical coordinates and Gaussian surfaces
  • Basic proficiency in electrostatics and field calculations
  • Study the derivation of electric fields using Gauss's Law in various geometries
  • Explore the implications of charge density on electric field strength
  • Learn about the behavior of electric fields in conductive materials
  • Investigate applications of Gauss's Law in real-world electrostatic problems
Students and professionals in physics, electrical engineering, and anyone interested in understanding electrostatics and electric field calculations in conductor-shell systems.
chillaxin
A long straight conducting rod (or wire) carries a linear charge density of +2.0uC/m. This rod is totally enclosed within a thin cylindrical shell of radius R, which carries a linear charge density of -2.0uC/m.
A) Construct a Gaussian cylindrical surface between the rod and the shell to derive then electric field in the inner space as a function of the distance from the center of the rod.
B) Construct a Gaussian cylindrical surface outside both the rod and the shell to calculate the electric field outside the shell.
This is what i have so far.
E=q/4piEor^2
E=+2.0uC/m / 4pi8.85x10^-12(-2uC/m)^2
E=4.5x10^9Nm^2/C
E=q/4piEor^2
E=4.5x10^9Nm^2/C
It asks you to apply Gauss' law:
[tex]\oint E\cdot dA = \frac{Q_{encl}}{\epsilon_0}[/tex]
If you pick a gaussian surface through which you know E is constant due to all points on the surface being equidistant from equal charges, the integral is simply
[tex]E\cdot A = \frac{Q_{encl}}{\epsilon_0}[/tex]
Pick a surface that is inside the cylinder that fits that description and do the calculation.
AM
