| Thread Closed |
rubber wheel (angular acceleration) |
Share Thread | Thread Tools |
| Oct25-06, 08:52 PM | #1 |
A small rubber wheel is used to drive a large pottery wheel, and they are mounted so that their circular edges touch. The small wheel has a radius of 2.0cm and accelerates at the rate of 7.2rad/s^2 and it is in contact with the pottery wheel (radius 25.0cm) without slipping. Calculate:
a) the angular acceleration of the pottery wheel b) the time it takes the pottery wheel to reach its required speed of 65rpm My approach: What I can determine with the rubber wheel: 0.02m = r 7.2 rad/s^2 = angular acc Atan= (0.02)(7.2) = .144 m/s^2 I think the Atan is the radial acceleration for the pottery wheel but I'm not sure. If I can get the angular acceleration I can solve for t using Wot + 1/2 (angular acceleration) t^2 = theta ( I think). If I assumed Atan was the radial acceleration I attempted to solve for w in Radial Acceleration= w^2r w = 0.76m/s I'm not sure what to think of my approach. The key is what type of acceleration is transferred from the rubber wheel to the pottery wheel? Thanks in advance. This forum is great! |
| Oct26-06, 02:25 AM | #2 |
Recognitions:
The angular displacement of the big wheel is proportional to the angular displacement of the small wheel. That means the angular velocities and accelerations are also proportional with the same ratio. How many radians does the big wheel rotate when the small wheel rotates one radian?
| Oct26-06, 07:24 AM | #3 |
So R2 is 12.5 times the radius of the rubber wheel. This means that the angular acceleration of the second wheel is 1/12.5 the given angular acceleration of the rubber wheel? This also means the torque on the second wheel is 12.5 times the torque on the rubber wheel?
Does this sound correct? Thanks. |
| Oct26-06, 08:30 AM | #4 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: rubber wheel (angular acceleration)
| Angular Acceleration of a Moving Wheel | Introductory Physics Homework | 6 | ||
| Weight and Wheel !!! (Linear and Angular Acceleration) | Introductory Physics Homework | 2 | ||
| Angular Acceleration of a Moving Wheel | Introductory Physics Homework | 1 | ||
| Angular Momentum - Wheel with unequal radius | Introductory Physics Homework | 2 | ||
| Wheel and angular velocity | Introductory Physics Homework | 2 | ||
