HW help (Double Slit, Resolving power etc)
The discussion revolves around a double-slit experiment involving calculations related to interference patterns produced by different wavelengths of light. Participants explore the conditions for constructive and destructive interference, as well as the relationship between fringe order and wavelength.
  • Mixed
  • Participants discuss the equations governing the double-slit experiment, particularly focusing on the conditions for both bright and dark fringes. There are attempts to clarify the relationship between wavelength, fringe order, and distance to the screen.
Some participants have provided guidance on the equations to use for calculating fringe positions, while others have raised questions about the specific values of fringe order and how they relate to the wavelengths involved. There is an acknowledgment of the need to differentiate between the orders of the fringes being analyzed.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use to arrive at solutions. There is also a focus on ensuring clarity regarding the definitions and setups of the problems presented.
Alt+F4
(a) A double-slit experiment is set up using red light (l = 708 nm). A first order bright fringe is seen at a given location on a screen. What wavelength of visible light (between 380 nm and 750 nm) would produce a dark fringe at the identical location on the screen?
l = nm
All right so i know
d * sin theta = m * wavelength
How do i find the Distance and the angle?
The condition for constructive interference is what you have written down (i.e. peak on peak), but destructive interference happens when you have a trough meet a peak, i.e. there is a half wavelength difference so for destructive interference (dark fringe) [tex]dsin (\theta) = (m + 0.5)\lambda[/tex]. You should be able to go from there.
(b) A new experiment is created with the screen at a distance of 1.8 m from the slits (with spacing 0.08 mm). What is the distance between the second order bright fringe of light with l = 691 nm and the third order bright fringe of light with l = 414 nm? (Give the absolute value of the smallest possible distance between these two fringes: the distance between bright fringes on the same side of the central bright fringe.)
Ok so
D sin theta = m * wavelength
Distance is 2.2?
I am going to find theta
m = 1
wavelength is 698 in one part, and then i do the quation again for 413 right?
Ok so
Distance is 2.2?
m = 1
Don't lose track of the statement about the different orders of the finges. What is m for second order, and for third order?
2 for second order, and 3 for third order
got the answer, thanks
You don't actually need to find the distance at all. You will have two equations equal to [tex]dsin (\theta)[/tex], and you just have to solve for the 1 unknown (wavelength).
and that would be?
.00315 m
Yes that's correct for (b). What answer did you get for (a).
11K
