How to Determine the Lagrangian and Equations of Motion for Given Systems?
  • Thread starter Thread starter astronomophosis
    Lagrangian Method
This discussion focuses on determining the Lagrangian and equations of motion for two specific mechanical systems: a heavy ring on a frictionless rod and a spherical pendulum. For the first problem, the Lagrangian is derived considering the mass M, spring constant k, and the angle α between the rod and the wall. The second problem involves formulating the equations of motion for a spherical pendulum, which requires understanding the three-dimensional motion of the pendulum. Both problems emphasize the application of Lagrangian mechanics to derive motion equations.
  • Understanding of Lagrangian mechanics
  • Familiarity with spring dynamics and Hooke's Law
  • Knowledge of spherical coordinates and their application in mechanics
  • Basic principles of oscillatory motion
  • Study the derivation of the Lagrangian for systems with constraints
  • Learn about the Euler-Lagrange equation and its applications
  • Explore the dynamics of non-linear oscillators
  • Investigate the motion of pendulums in three dimensions
Students and professionals in physics, mechanical engineering, and applied mathematics who are interested in advanced mechanics and the application of Lagrangian methods to complex systems.
astronomophosis
Problem 1:
A heavy ring of mass M can slide on a frictionless rod. The rod is attached to a wall at one end with a bracket and the other end hangs downward, so the angle between the rod and the wall is α. One end of a massless spring of constant k is attached to the bracket and the other end is connected to the ring. Determine the Lagrangian for the system and equation of motion.
Problem 2:
Obtain the equations of motion for a spherical pendulum, that is, a pendulum that is not constrained to oscillate in a plane.
I can help with these problems but I need to see what you've tried first.
