Effect of Humidity on Air Density & Coefficient of Friction
  • Thread starter Thread starter ritwik06
The discussion revolves around the effects of humidity on air density and the definition of the coefficient of friction. Participants are exploring the relationship between humidity and air density, questioning how the replacement of air molecules by water vapor affects overall density, while also clarifying the definition of the coefficient of friction.
  • Participants are attempting to understand whether increased humidity leads to an increase or decrease in air density, with some suggesting that water vapor replaces heavier air molecules, while others argue that the overall density decreases due to the lower molecular mass of water. Questions about the definition of the coefficient of friction are also raised.
The discussion is active, with participants presenting differing viewpoints on the impact of humidity on air density. Some have offered clarifications and definitions, while others are questioning assumptions and interpretations without reaching a consensus.
Participants are navigating the complexities of gas composition and molecular mass, with references to the proportions of gases in the atmosphere and the implications of water vapor presence. There is an ongoing debate about the fixed nature of these proportions and their effects on density.
ritwik06
1. What is the effect on the density of air if humidity increases?
2. Define co-efficient of friction.
What do you think?
Hootenanny said:
What do you think?
well, I think that:
1. with increase in humidity the density should increase.
2. co-efficient of friction is the ratio of the force of friction to normal reaction(the weight of the body in most cases)
Please let me know your opinions! :-p
Please will anybody tell me whether I am right?
Air is primarily made up of diatomic molecules of oxygen (~21%) and nitrogen (~78%), with water ranging from 0 to 7%. Now 21% + 78% is 99%, so obviously these numbers apply to dry air. When the humidity is high, water molecules are replacing the diatomic oxygen and nitrogen molecules. How does the mass of a water molecule compare to the masses of oxygen and nitrogen molecules?
#2 looks good, except I wouldn't say weight in most cases. I would perhaps say weight for horizontal surfaces.
Well, of course the density water molecules is less than the density of nitrogen and oxygen molecules. But this doesn't seem to be a genuine reason. the amount of nitrogen and oxygen is fixed in air that is 99%. They arent replaced. Only the water vapour molecules take the intermolecular spaces. This should increase the density. Dont you think so?:bugeye:
I agree with you for the second one! Thanx :biggrin:
This is not so. Remember that a gas of a set volume always contains the same number of molecules (one mole of an ideal gas at STP occupies about 22 litres).
Well what do you mean to say whether the density increases or decreases?
Since the molecular mass of a water is less than the molecular mass of air and the number of molecules in a set volume of a gas is constant, it follows that making the air more humid (substituting water molecules for air 'molecules') would decrease that mass contained in the set volume. Hence, the density would decrease.
I can't see any reason to agree to both of your posts at once. Please try to look from my point of view. You said that 1 mole of air has 99% of Nitrogen and Oxygen! 0.03% is always Carbon dioxide. Now the rest portion 0.97% consists of water vapours, dust, traces of other gases, pollen grains. etc. etc. The ratio of the last category of substances is not fixed. Now tell me if all the 0.97% of air has water vapours, ie. now the air is saturated with water. Will the density not increase? :biggrin:
No, for the reasons I stated above, the density will decrease. The number of molecules in a volume of air remains constant. Therefore, if we introduce water vapor into air these molecules of water must displace air 'molecules'. Therefore, the density must decrease since the molecular mass of water is less than the molecular mass of air. I never mentioned the proportions you quote and neither me nor OlderDan stated that any of the proportions are fixed.
Well thanks :biggrin:
Do you understand why this occurs?
  • · Replies 30 ·
