Force and Projectile Motion Questions
The forum discussion centers on two physics problems related to force and projectile motion encountered by a university student. The first problem involves calculating the force required to push a lawnmower at a constant speed on a surface with friction, considering the angle of the handle and its effects on normal force and friction. The second problem requires determining the speed at which a quarterback must throw a football to reach a moving target. Key insights include the identification of a critical angle where the applied force becomes infinite and the relationship between the horizontal and vertical components of forces in both scenarios.
  • Understanding of Newton's laws of motion
  • Knowledge of friction coefficients (static and kinetic)
  • Familiarity with trigonometric functions and identities
  • Ability to analyze free body diagrams (FBD)
  • Study the derivation of force equations in frictional contexts
  • Learn about critical angles in physics and their implications
  • Explore projectile motion equations and their applications in sports
  • Practice solving problems involving free body diagrams and force components
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of force and motion in real-world applications, particularly in sports and mechanical contexts.
Canadian
Hello, I am in a introductory type first year physics class at univeristy.
Just got the midterm back, I got 80% (not too bad considering the class average was 55%).
Anyway there were two questions that I got completely wrong, not even a partial mark.
First Question: Part A:Consider a lawnmower of weight W which can slide across a horizontal surface with a coefficient of friction (mu) . In this problem the lawnmower is pushed using a massless handle, which makes an angle theta with the horizontal. Assume that , the force exerted by the handle, is parallel to the handle. Take the positive x direction to be to the right and the positive y direction to be upward. Find the magnitude of the force required to slide the lawnmower over the ground at constant speed by pushing the handle. Express the required force in terms of given quantities.
Part B:The solution for part a has a singularity (that is, becomes infinitely large) at a certain angle (theta "critical") . For any angle , the expression for F(handle) will be negative. However, a negative applied force F(handle) would reverse the direction of friction acting on the lawnmower, and thus this is not a physically acceptable solution. In fact, the increased normal force at these large angles makes the force of friction too large to move the lawnmower at all. Find an expression for tan(theta critical)
Question 2: Quarterback Fred is going to throw a pass to tight end Doug. Doug is 20 m in front of Fred and running straight away at 6.0 m/s when Fred throws the 500 g football at a 40 angle. Doug catches the ball without having to alter his speed and runs for the game-winning touchdown. How fast did Fred throw the ball?
For question one, I found the horizontal and vertical components of the pushing force set them to 0 and then set them equal to each other then solved for F, I think for this question I am missing something to do with the force of friction and how it is affected by the pushing handle. I didn't get part two.
For question 2 my scrap paper sheet was lost, so I'm not exactly sure what I did but the answer I got (was wrong) was that the speed of the ball was greater than 6 m/s. The marker wrote on the sheet that they were looking for a single numerical value.
Any help would be greatly appreciated, it's not worth anything now I just want to understand what I did wrong and what I should have done to solve the problems.
Thanks
Thanks
For quiestion 1, originally Posted by Morsetlis,
Suppose there is a diagonal downward force from top right to bottom left on an object with weight w on a surface with coefficient of friction u (static/kinetic friction aren't distinguished in this question.)
The diagonal downward force is a vector F_h with angle theta to the horizontal.
I have already figured out that, for at a certain angle theta, the force F required to push the object to overcome its frictional resistance, is
F_h = (uw) / (costheta - usintheta)
However, since every positive change in angle will reduce the horizontal component and increase the vertical component, this will increase the effect normal force on the object, which is N = u + F_hsintheta, thus also increasing the frictional force, F_f = uN.
At a certain angle, called the Critical Angle, F_hcostheta, which is the horizontal force required to move the object, will be equal to F_f, the frictional force opposing F_h. Increasing that angle will leave F_h < F_f and the object will not be able to move. After a certain interval of increasing degree, F_h will be greater than F_f once more, but the object will now move in the opposite direction.
Knowing that the Critical Angle forms a singularity at F_h = (uw) / (costheta - usintheta) so that F_h goes to infinity, I know I have to solve for (costheta - usintheta) = 0.
However, I also need to know the tangent of the Critical Angle, and this is not a happy answer, since my answer for the Critical Angle also included arcsin functions.
Phantom says: I think i have read the problem corectly, and it appears that you have correctly solved part a, and that your only question relates to part b. You again are correct that solving (costheta =usintheta) will give the critical angle. Try dividing both sides of the equation by costheta to see what you get. What is sintheta/costheta equal to in terms of the trig identities?
This might help O Canada! but you need a good FBD to help explain it. Ask again if u need more help.
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 22 ·
