Vector Spaces and polynomial functions
The discussion centers on the properties of polynomial functions of degree 2 and their classification as a vector space. Participants clarify that the set of polynomials of exact degree 2 is not closed under addition or scalar multiplication, as the sum of two degree 2 polynomials can yield a polynomial of lower degree. The key takeaway is that while polynomials of degree less than or equal to 2 form a vector space, those of strictly degree 2 do not, due to the absence of an additive identity within the set.
  • Understanding of polynomial functions and their degrees
  • Knowledge of vector space axioms, particularly closure under addition and scalar multiplication
  • Familiarity with the concept of additive identity in vector spaces
  • Basic algebraic manipulation of polynomials
  • Study the properties of vector spaces, focusing on closure under addition and scalar multiplication
  • Learn about polynomial functions of different degrees and their characteristics
  • Explore examples of vector spaces that include polynomials of varying degrees
  • Investigate the implications of having an additive identity in a vector space
Students of mathematics, particularly those studying linear algebra, educators teaching vector space concepts, and anyone interested in the properties of polynomial functions.
endfx
I'm really confused about a question I came across in my textbook.
It basically says this:
Consider the set of polynomial functions of degree 2. Prove that this set is not closed under addition or scalar multiplication (and therefore not a vectorspace).
I'm confused because I think it is closed under addition and scalar mult.
example:
f(x) = ax^2 + bx + c
g(x) = dx^2 + ex + f
(f+g)(x) = (a+d)x^2 + (b+e)x + (c+f)
(sf)(x) = (sa)x^2 + (sb)x + sc
both results should be in the set of polynomial functions of degree 2.
Why would the question say it is not closed under addition and scalar mult. ??
Am I missing something very basic here, or could it be a trick question or something?
Thanks!
The set of polynomials of degree less than or equal to 2 is a vector space. If you only have polynomials of degree 2, this is no longer true.
I'm not sure I understand why this is.
So then the set of functions is only: ax^2
Is this what you mean? If it is, I'm still not sure why the set wouldn't be closed under addition and scalar mult. :
f(x) = ax^2
g(x) = bx^2
(f+g)(x) = (a+b)x^2
(sf)(x) = (sa)x^2
{where s is a scalar; a and b are coefficients)
I'm not sure what I'm missing in this problem. :(
And thanks for the quick reply master_coda
-Confused
x^2 + (-x^2) is not a degree 2 polynomial.
no but x^2 + (-x^2) = 0
0 is in the vector set.
then what is the additive zero element of your set?
I'm not sure what you mean by additive zero element.
And just so I'm clear, is 2x^2, for example, a degree 2 polynomial that would be in the set that the above question is asking?
i.e. degree 2 polynomials can still have coefficients, right?
every vector space must contain an element denoted O or 0 such that for all vectors u, u+O=O+u=u.
Oh, yeah, I get what you mean now.
Wouldn't the additive zero element be 0^2?
what's the degree of 0^2=0?
I'm sorry. But I don't see the point your trying to get across here.
f(x) = ax^2
g(x) = bx^2
(f+g)(x) = (a+b)x^2
(sf)(x) = (sa)x^2
Why doesn't this show that its closed under addition and scalar mult?
when you said:
"x^2 + (-x^2) is not a degree 2 polynomial."
doesn't that support the following axiom:
"For every element u of V, there exists an element called the negative of u, denoted -u, such that u + (-u) = 0."
(This is one of the axioms from my text that needs to be satisfied in order for something to be a vector space)
Which further supports why I think this is a vector space.
Thanks for the hints so far, but don't seem to be grasping why this isn't a vector space. :(
If I'm understanding this correctly...
First, you must realize that (for example) x + 1 is not a member of the set of second degree polynomials. It is however an element of the set of polynomials of degree <= 2. This is crucial.
Now, add two polynomials of degree 2. Can you say with certainty that this sum will also be a polynomial of degree 2 (unless you place certain restrictions on the coefficients)? No, consider (x^2 + 3x + 1) + (-x^2 + x + 3) = 4x + 4, which is a polyonomial of degree 1. Hence the set of second degree polynomials is not closed under addition.
However, you /can/ say that the sum of two second degree polynomials will be /a/ polynomial, and that its degree will be at most 2, hence the set of polyonomials of degree <= 2 is closed under addition (and is a vector space).
And to REALLY get home something that you need ton understand: 0 is a constant polynomial, it has degree 0, as do all the polys f(x)=constant. How did you arrive at 0^2? Or if you like write down a polynomial in x with a non zero x^2 coeff that when added to every other polynomial leaves it unchanged.
In order for you to use that axiom, you need to assume the set of degree 2 polynomials is a vector space. Since the set of degree 2 polynomials has no zero element, it is clearly not a vector space.
Thus you cannot draw any valid conclusions by assuming that it is a vector space, since that would be a false assumption.
f(x) = ax^2
g(x) = bx^2
(f+g)(x) = (a+b)x^2
(sf)(x) = (sa)x^2
Because (a+b)x^2 isn't always a degree 2 polynomial.
Thanks very much to everyone who posted to my questions. Everybody's reply helped be understand and solve the problem.
Thanks again, I really appreciate it!
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 0 ·
9K
  • · Replies 25 ·
