Problem Involving Elastic Collision .
The discussion revolves around an elastic collision problem involving two 10 kg balls, where one ball is moving at 10 m/s and the other at 40 m/s in opposite directions. Participants are exploring how to determine the speeds of both balls after the collision using principles of conservation of momentum and kinetic energy.
  • Participants discuss the need to apply both conservation of momentum and conservation of kinetic energy to solve for the final velocities of the balls. Questions arise about how to set up the equations correctly and the implications of using different notations for the variables involved.
There is an ongoing exploration of the correct application of conservation laws, with some participants confirming that the original poster is on the right track. However, there is no explicit consensus on the final outcomes, as discussions continue regarding notation and the setup of equations.
Participants note the importance of consistent notation across different equations to avoid confusion, and there is mention of the implications of directionality in momentum calculations, particularly in the context of inelastic collisions.
bengaltiger14
Problem Involving Elastic Collision...
There are two ball that are both 10kg. The velocity of ball 1 is 10 m/s and the velocity of ball 2 is 40 m/s in the opposite direction of ball 1. They collide to form an elastic collision. Determine speed of both balls after collision?
Am I starting off on the right foot?
1/2m1v1^2 + 1/2m2v2^2 = 1/2m1v3^2 + 1/2m2v4^2
=1/2(10kg)(10m/s)^2 + !/2 (10kg)(40m/s)^2 = 1/2(10)V3^2 + 1/2(10)V4^2
Solve for V3 and V4 and that should be my answers correct?
You can't solve for v3 and v4 without using the fact that momentum is conserved. Then you have two equations with two unknowns, which is solvable.
So far, so good. But how can you solve for two variables with only one equation? What else is conserved that will give you a second equation?
Ok...Kinetic Energy is conserved and so is momentum...
So..Conservation of Momentum yields me:
m1v1 + m2v2 = m2vx + m2vy
Where vx and vy are my unknowns
Do I solve for vx in the momentum equation and then plug that anwer in for my V3 on my original or something like that?
Why not use the same symbols that you used in your conservation of energy equation?
yes... Than would be easier. I just named them different because they were different equations. But, I am going on the right track now?
By using conservation of energy and conservation of momentum, you are on the right track. (Your notation of Vx and Vy bothers me a bit--I hope you are not thinking in terms of x and y components.)
No. I am not thinking in terms of x and y components. I just simply changed the notations because I was looking at two different formulas.
Cool. But the same quantities should have the same notation, even if they appear in different equations. That's how you'll end up with two equations and two unknowns--not four unknowns. :wink:
No problemo. But it's a bit more practical to name the velocities after the collision as v1' and v2'.
So, is my answer correct. After doing calculations, I determined that ball 1 transferred it velocity to ball 2 and vise versa. Ball 2 is now at 10 m/s and ball 1 is now at 40 m/s.
That's right--they swap speeds.
Cool...Thanks for all your help everyone
Just for general knowledge. If the collison were inelastic and the formula would be:
Vfinal = (m1v1 +m2v2)/m1 + m2
Would I need to set v1 or v2 to negative since they are going in the opposite direction?? When I set v2 to negative, the final V= -15m/s.
When I leave it positive, Vfinal = 25 m/s
This should help: http://hyperphysics.phy-astr.gsu.edu/hbase/inecol.html" .
The link did not work...
It should work for you.
Vfinal = (m1v1 +m2v2)/(m1 + m2)
Yes. (See my added brackets.)
Absolutely! If v1 is positive, v2 must be negative. Momentum is a vector--direction matters.
  • · Replies 16 ·
  • · Replies 22 ·
