Cooler water to the radiators farther away?
  • Thread starter Thread starter TSN79
    Cooler Water
The discussion revolves around the temperature distribution in radiator heating systems, particularly focusing on how the temperature of water changes as it travels through pipes to reach radiators located at varying distances from the heat source. Participants explore the implications of heat loss, insulation, and the methods used to ensure consistent heating throughout a space.
  • Some participants express concern that only the first few radiators may receive water at the intended supply temperature, suggesting that water cools significantly by the time it reaches distant radiators.
  • Others propose that proper insulation can minimize heat loss, making the temperature difference negligible.
  • One participant mentions the use of computer software to calculate heat transfer for each radiator, taking into account various factors such as room size and insulation type to achieve consistent temperatures throughout the house.
  • Another participant provides a method for calculating heat loss using the R value of insulation, surface area of pipes, and temperature differences, indicating that it is feasible to perform these calculations manually.
  • Some participants discuss the configuration of piping systems, noting that in many commercial and residential settings, supply and return water are separated, which helps maintain higher temperatures in remote radiators.
  • There is a mention of two piping systems: "reverse return" and "direct return," with explanations of how each system affects the temperature distribution in radiators.
  • One participant shares a specific example involving calculations of heat loss based on pipe dimensions and insulation, suggesting that the temperature drop can be minimal.
Participants do not reach a consensus; there are multiple competing views regarding the effectiveness of insulation, the complexity of calculations, and the impact of different piping systems on temperature distribution.
Participants acknowledge that calculations depend on various assumptions, such as the specific conditions of the house and the properties of the materials used. There are also unresolved mathematical steps in some of the calculations presented.
TSN79
I'm wondering about radiators. A system runs with a supply and return temperature of 90/70 degrees C. But won't only the first few radiators have this actual temperature since the water reaching the radiators far away will have cooled considerably on the way...? How does one make up for this?
With insulation, usually the loss will be negligible.
Computer software is used to calculate heat transfer for each radiator, room size, windows, doors, exterior wall and insulation type. The physical radiator size is also adusted for different water temps at each stage of the loop.
The end result is (hopefully) a consistent temp througout the house.
There is a tremendous amount of calculation that goes into this.
Actually, since the units of R value of insulation are just hr*ft^2*F/btu, it isn't that hard to calculate the loss. You need the surface area of the pipe and the temperature difference between the water and air. Then using the specific heat of water, you can find how much it drops in temperature.
Sure, its possible to do it by hand.
Probably take you about a week to do it though.
It takes an hour or two just to pump all the required parameters into the computer, depending on how complex the house is.
In most commercial and some residential settings, the supply water and the return water are separated in different pipes. So the water that has run through a near radiator then goes to return, while still hot water continues to the remote rads. Insulation on the pipes reduces the loss to the remote rads and they see nearly the same entering temp as close rads.
Check out "reverse return" and "direct return" piping systems.
Reverse return takes the return water from the farthest rad supplied back to the boiler first and the water returning from the closest rad goes back last.
Direct return is piped so that the farthest supply is also the farthest return, the closest supply is also the closest return.
Naa, it's about 5 minutes and you just need a calculator.
Example:
Lets say the house has 200' of 1" piping. That's 52 sq ft. of surface and a volume of 13 cu ft.
If your insulation is R5, your water is 180 degrees, and your room is 70, that's 1144 btu/hr.
Since a btu is 1 degree of temperature rise per pound and there are 62.4 lb/cu ft, that's 1.4 degrees F per hour.
Negligible. [someone can check my math...]
  • · Replies 67 ·
14K
