| Thread Closed |
Center of Mass! |
Share Thread | Thread Tools |
| Oct31-06, 03:44 PM | #1 |
Center of Mass!
Question: Three cubes of sides l, 2l, and 3l are placed next to one another (in contact) with their centers along a straight line and the l=2l cube in the center. What is the position, along the line, of the CM of this system? Assume the cubes are made of the same uniform material.
My reasoning: So the equation for CM= M1XI +M2X2 + M3X3/ TM ... where M= mass, and X= distance ....So M(l +2l +3l)/3m = CM M(6L)/3m = 2L So, I got the center of Mass is 2L I dont think my answer is correct, and even if my approach is correct. It is labeled a pretty easy problem, but I get really confused with problems without numbers. Also, I am not sure if you can conclude the total mass is 3M considering that means all the cubes would have to be the same mass .... and I also do not know what the question maker meant when he wrote the l=2l cube in the center ..... Please help! |
| Oct31-06, 03:48 PM | #2 |
Recognitions:
The coordinates X1, X2, and X3 are the coordinates of the center of mass of each cube. So, all you have to do is place the origin wherever you want and start to calculate. If you place the origin at the beginning of the first cube, then X1 = 0.5 L, and so on..
| Oct31-06, 03:53 PM | #3 |
radou ... thanks for the help but i am still confused.... how would you find the total mass of the cubes??
| Oct31-06, 03:55 PM | #4 |
Recognitions:
Center of Mass! |
| Oct31-06, 03:59 PM | #5 |
finding the volume is easy , but how would you go about finding the density? is it simply a known value?
| Oct31-06, 04:08 PM | #6 |
Recognitions:
| Oct31-06, 04:23 PM | #7 |
| Oct31-06, 04:26 PM | #8 |
is the answer 3.08Lo (thats what i got) ???
| Oct31-06, 04:52 PM | #9 |
Recognitions:
According to my calculation, it's 3.83L. But I may be wrong. Nevertheless, it's important you understand the principle.
| Oct31-06, 04:54 PM | #10 |
yeaaa... i just did it again and got 3.83L ..... but radou, how does that make sense??
| Oct31-06, 05:02 PM | #11 |
Recognitions:
| Oct31-06, 05:24 PM | #12 |
well........if the center of mass is 3.83L .... then wouldnt the center of mass be out of the object given (which is impossible)?
| Oct31-06, 06:20 PM | #13 |
Recognitions:
| Oct31-06, 06:42 PM | #14 |
thanks radou!!!!!!!!!!!!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Center of Mass!
| Center of gravity (it's not center of mass!!!) | General Physics | 28 | ||
| the geometric center of the Earth and the center of mass | Classical Physics | 9 | ||
| Can two objects with the same center of mass oscillate about that center? | Introductory Physics Homework | 0 | ||
| Help with problem of Center of mass, linear mass density and total mass | Introductory Physics Homework | 1 | ||
| The center of Mass perfectly match the center of Force-> | General Physics | 9 | ||
