Finding the Correct Function and Limits for a Polar Double Integral
The discussion revolves around evaluating a polar double integral, specifically focusing on identifying the correct function and limits for integration. The original poster expresses uncertainty about their chosen function and integration limits within the context of polar coordinates.
  • Exploratory, Assumption checking
  • The original poster attempts to evaluate the integral using the function sin(r^2) with limits from 3 to 6 and 0 to 2π, but questions the correctness of their approach after not obtaining the expected result. Other participants question the need to convert the area element from dA to dr dθ and discuss the implications of using degrees versus radians in calculations.
The discussion is active with participants exploring different interpretations of the problem. Some guidance has been offered regarding the conversion of units and the area element, and there is acknowledgment of a potential misunderstanding regarding the use of degrees versus radians. However, no explicit consensus has been reached on the correct function or limits.
Participants are navigating the complexities of polar coordinates and the specifics of the integral setup, including the importance of correctly identifying the function and limits. There is an indication that previous homework has consistently used radians, which may influence the current problem's approach.
glid02
I'm having trouble finding the function and/or the limits to this problem:
Using polar coordinates, evaluate the integral http://ada.math.uga.edu/webwork2_files/tmp/equations/01/19aeef09224e0fca11ef9d6e45fb311.png where R is the region http://ada.math.uga.edu/webwork2_files/tmp/equations/21/9cc2c610adbc73bdcbe1922b3dea321.png
I've tried the function as sin(r^2) with the limits as 3 to 6 and 0 to 2pi, but that does not give the right answer.
That would give -1/2*cos(r^2) which gives .0893 dtheta, which is then
.0893*2pi.
I'm pretty sure I'm doing the integrals correctly, I think I just have the function wrong. If anyone can help me out I'd appreciate it.
Thanks
You realize you need to change it from dA to [tex]drd\theta[/tex] right?
[tex]r dr d\theta[/tex]. But he did that, and -1/2*cos(r^2) looks right to me. Your limits look good too. I don't see where you are getting .0893 though.
I evaluated 1/2*cos(r^2) from 6 to 3
-1/2(cos(36)-cos(9))
He is using degrees rather than radians?
It's in radians, all the other homework has been and I just tried the answer with 360 instead of 2pi.
Max meant that your calculation used degrees, when you should have used radians... and I think he's right.
Ah, you are right. That worked, thanks a lot.
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 17 ·
