| New Reply |
Extra Dimensions in String Theory |
Share Thread | Thread Tools |
| Nov2-06, 05:24 PM | #1 |
Hello, folks - this is my first post here. I am hoping some of you will be kind enough to help me understand something I have struggled with for a long time.
A brief background: My lifelong interest in science fiction led me to start reading about relativity and quantum physics around 20 years ago. However, I am stricly a layman with no mathematical formalism. What knowledge I have of these topics comes mostly from reading authors like Paul Davies, Michio Kaku. John Gribbin, Steven Hawkings and other popularizers of physics. When I read such books, I am always acutely aware that the language of physicists is math, and that I am getting my information from "translators". So when I run into concepts that I have trouble accepting, I always wonder whether the problem is the concept - or the translation. So my question has to do with the "higher spatial dimensions" of string theory. I am aware that a "dimension" to a mathematician is not necessarily the same thing as a "dimension" to a classical physicist, or anyone using dimensions in the real world. A mathematician's dimensions can be abstractions, but a physical dimension is a usable means of measurement. If you'll forgive a simple example - a mathematician can draw two crosses - two sets of axes - on a sheet of paper. He can label one set of axes, "x,y", and one set of axes "a, b", and say that he has "four spatial dimensions" - right? But obviously the surface of his sheet of paper still remains two dimensional. Two measurements at right angles to each other are "necessary and sufficient" to locate any point on the paper. My question is - are the "higher spatial dimensions" of string theory mathematical abstractions only? Do physicists actually believe that these extra dimensions are describing some unseen place, some space, that can't be measured and located within the standard three dimensions of length. width, and depth? What exactly is a "higher spatial dimension" to a theoretical physicist? I have clues that the literal existence of these higher spatial dimensions is intended to be taken seriously. I've heard them described as "compactified", and the analogy of the interior of a garden hose, which looks one dimensional from a distance but reveals other dimensions close up. I can only accept this as a mathematical abstraction. It's the same as saying "small measurements are in a different dimension than big measurements." A mathematician could say, "I define anything bigger than a meter as dimension X and smaller than a meter as dimension Y" - but to suggest that creates a new physical space, or a higher dimension as laymen think of such things, makes no sense to me. I've heard that the extra spatial dimensions are curled up into manifolds. A dimension in the real world is a means of measurement, not a place, not a thing. How can a means of measurement be curled up? If I curl up a tape measure, I can still locate any point on that tape measure with straight yardsticks in the standard three dimensions of length, width, and depth. The whole idea of "higher spatial dimensions" and "hyperspace" just sounds so Flatland to me. It seems the exact same as Flatlanders talking about "higher area dimensions" or "hyperplanes". Sorry for revealing my bias. Can anyone explain whether these higher spatial dimensions are meant to be taken literally - what they are - how they describe any space that can't be measured in 3 dimensions? (Just to let you know, I'm aware of time as a dimension and am leaving it out of my comments as a convenience.) If anyone can help me understand this better, in layman's language, I would be extremely grateful. Thanks in advance! |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov2-06, 05:41 PM | #2 |
| Nov3-06, 04:34 AM | #3 |
As far as I understand it the extra dimentions in string theory arise when you go from the a the classic description of string theory to the quantum description. It comes about because the theory must obey certain symmetry principles which force higher dimentions into the theory. Usually this is called the "conformal anomally".
Since as of yet experimental evidence for string theory is lacking, it is unknown whether these dimentions are real. Although because there are many string theories, some give x dimentions, some gives y dimentiions physicists are wondering whether the number of space time dimentions is even significant at all. What Kea said though is very intresting. Can you refer me to some introductory article on the subject? |
| Nov3-06, 05:01 AM | #4 |
Recognitions:
| Nov3-06, 08:32 AM | #5 |
Kea - thanks for giving me a direction to look in. I'll do searches on categorical dimensions and category theory and see if that helps me understand better.
Gouranja - ahve you ever considered the possibility that the lack of experimental evience may actually be connected to the fact that the theory is conceptualized in terms of extra spatial dimensions that can't be physically measured? El - if the extra dimensions are real, how do you conceive of them? Are they "somewhere else"? Can I point a ruler at them? If these extra dimensions are in the particles (excuse me, strings) that make up my body, my desk and so on, they must be in the same physical place that I am in. So why would I not be able to locate them within the standard 3 spatial dimensions? Also, how do you conceive of a "curled up dimension" if a dimension is a means of measurement? I refer you back to my example of a curled up tape measure, every point of which can still be located in the standard 3 dimensions. I can see how, abstractly, a mathematician can define a curled frame of reference and call it a dimension - but on a physical level, I don't understand how an extra curled axis takes me outside of anything I can measure with 3 dimensions. Thanks you, all. |
| Nov3-06, 09:30 AM | #6 |
Recognitions:
An analogy I like to think of is the following: Consider a 1-dimensional world; an infinitely long line, with a creature living in it. The creature can only move in (and percieve) the directions backwards and forwards. Now add another dimension so that the universe becomes an infinitely long cylinder with a radius much smaller than the size of the creature. Question is, will the creature really be able to differ between the universes? Will it be able to determine wheter it is living in a 1d-universe, or a 2d-universe with one of the dimensions curled up (the direction around the cylinder)? For example, distances between points on a macroscopic scale (that is at the scale of the creature) doesn't depend very much on which "curled up dimension"-coordinates the points have. Then we also have the quantum effects. According to quantum machanics particle momenta along the curled up dimension can only take on certain quantized values. The smaller the compactification radius, the larger the smallest allowed momenta will be. Hence a particle need to be very energetic to be allowed to move in the new dimension. Since the creature will just see that the energy of the particle has increased, while the momentum along the large dimension is still the same, it will interpret this as a new much heavier particle, a so called Kaluza-Klein particle (which indeed is a proposed dark matter candiate). This was an example of a universal extra dimension, which all particles are allowed to propagate in. The other, more string theroy inspired alternative, is that only gravity is allowed to propagate in the extra dimension, while standard model particles are confineded to our 3d-world. This would turn up as a deviation from the 1/r^2 law for gravity at distances depending on the radius of the extra dimension. Hope I didn't make a to large mess out of it. Here's some more nice reading: http://superstringtheory.com/experm/exper5.html http://superstringtheory.com/experm/exper5a.html |
| Nov3-06, 10:45 AM | #7 |
Thanks, El - I looked at your links. I have to admit there is much in them I don't understand, but I do feel I'm getting closer to understanding what the reality of these extra spatial dimensions is.
And they do sound to me like mathematical abstractions. I don't reject that these mathematical models may be describing something real. But the reality they seem to be describing is a complex interaction of forces that can be made more manageable in a mathematical way by introducing abstract dimensions. I don't see anything in what you posted, or in your links, that leads me to think I couldn't locate any of these forces in the three standard spatial dimensions. My feeling, as a layman reading about these things, is that extra dimensions are indeed necessary to explain quantum reality. But I suspect that a day will come when we will define these dimensions as something other than spatial. I can accept the idea of invisible forces interacting with the observable world to create quantum reality. But I can't see why something being invisible means that it is not locatable within an unbounded volume defined by length, width and depth. A compactified dimension that is too small to observe just says to me that you need smaller units of measure within the standard 3 dimensions. Take the "garden hose analogy". Imagine we're talking about a real garden hose, observed from orbit. Yes, the hose would look like a one-dimensional line to an astronaut in orbit - but if the astronaut returns to Earth, goes to the hose and measures its diameter with a ruler, would you seriously contend that our astronaut had discovered an "extra spatial dimension"? I can accept that abstract mathematics can define small measurements as a different dimension than big measurements. But in the physical world of real measurement, no matter how small or large a measurement is, I can locate it in an unbounded volume with only 3 - and no less than 3 - spatial dimensions. Provided, of course, that my measuring device has sufficiently small or sufficiently large calibrations. I have a ruler on my desk that measures 32nds of an inch. My car measures distances in miles. Is my car in a different dimension than my ruler?
| Nov3-06, 11:54 AM | #8 |
He is a good explainer and skilled at translating the content of equations into ordinary English. many of the people looking for a more fundamental basis for space time and matter call what they are working on "background independent" approaches because they do not assume at the start some fixed background continuum with a fixed number of dimension and a pre-structured geometry. To get a sense of the various "background independent" approaches people are working on, take a look at Dan Oriti's short essay at Christine Dantas' blog. http://christinedantas.blogspot.com/...t-daniele.html Dan is talking about a new book that Cambridge University Press will be bringing out (planned for early next year). The book is called Approaches to Quantum Gravity: towards a new understanding of space, time and matter It includes some string theory but it is mainly about 3 or 4 newer approaches which are more explicitly background indpendent and aim at a more fundamental picture. Oriti is the editor of the book which has chapters by some 20 or so people and also Q&A discussion---going to be a great book I think. He gives the table of contents in his short article about the book at Christine's blog |
| Nov3-06, 01:03 PM | #9 |
Also the lack of experimental evidence for these dimentions is because we don't have enough energy to to perform these experiments and "probe" the the particles at such small distances. |
| Nov3-06, 03:57 PM | #10 |
marcus!
Thanks for all the good links. I have been promoting a model which would fit the bill for Daniele Oriti. See my journal for details. I am looking forward to his book "Approaches to Quantum Gravity: towards a new understanding of space, time and matter" jal |
| Nov3-06, 04:35 PM | #11 |
Recognitions:
What I mean by a "real" extra dimension is that it is on equal footing with our usual 3. |
| Nov3-06, 06:07 PM | #12 |
EL - by asking whether the extra spatial dimensions are "real" or "mathematical abstractions", I'm afraid I've posed my question poorly. I'm aware that on some level even the 3 standard spatial dimensions in Euclidean space are a "mathematical abstraction".
So I hope you don't mind if I try to put the question more specifically. If I can go back to my example of a mathematician drawing axes on a sheet of paper - let's say he draws ten sets of axes instead of two. Let's say he has a perfectly valid reason for doing this, and everything he plots on these axes represents something "real". Assuming all his axes extend to the edges of the page, he can pick any set of axes and locate any point on the paper, including all points he's plotted on his other 8 axes. So two dimensions are what I'm calling "real" - what I should be calling "necessary and sufficient" - and the other 8 are what I'm calling "mathematical abstractions". So what I'm asking is - can all points within the 9, 10, or 25 spatial dimensions in string theories be located within a volume defined by 3 spatial dimensions? Are 3 spatial dimensions still "necessary and sufficient" to locate any point within the multiple extra dimensions? Or are the extra dimensions really intended to describe volumes where 3 dimensions are not sufficient to locate all points in physical space? To put it crudely, are the extra dimensions describing "somewhere else", or are they a more elaborate description of the normal way we think of 3-dimensional volume? Thanks again - I feel I am learning something here. |
| Nov3-06, 06:15 PM | #13 |
One would like to think of the 3 spatial dimensions as an emergent classical geometry from the appropriate abstract picture, which I claim uses categorical dimension rigorously in place of the literal string dimensions. These categorical dimensions have some correspondence with the number of 'particles' (but this cannot be well defined right here) that people mention as a means of defining rulers. It is correct to expect no observations of naive extra dimensions, but one should equally be reluctant to impose the usual 3 dimensions a priori upon the quantum theory. I apologise if unmathematical references for category theory in physics are hard to come by, but philosophers, for instance, have certainly written a great deal about these ideas.
| Nov3-06, 06:48 PM | #14 |
Recognitions:
However, this fourth coordinate will only be of importance for physics at scales comparable with the compactification radius of the extra dimension. If they are such that only gravity can propagate inside them, then maybe it's ok to say they are "somewhere else" since we can't put any matter or photons etc there. That is, we are stuck to our 3d-sheet which is embedded in the extra dimensions. But if they are universal I'm not sure I can agree they are "somewhere else". Btw, please correct me if I've got something wrong. |
| Nov4-06, 08:10 AM | #15 |
Kea, EL - one of my original questions was if "physicists actually believe" in the literal truth of higher spatial dimensions. From you two, it seems the best answer would be, "some physicists do believe in literal, higher spatial dimensions, some don't".
A few more questions: - do any of the extra dimensions have names? Are they identified with any familiar principles? For instance, is there a "dimension of angular momentum" or anything like that? I know in general terms that strings are thought to vibrate in these extra dimensions. If I think of a real-world vibrating object like a guitar string, I can imagine establishing a plane perpendicular to the string, and establishing a circular reference in that plane, a kind of protractor, to measure the angles at which the string vibrates. Could I then call those angles "spatial dimensions"? And is that analogous to any of the extra spatial dimensions in string theory? I'm trying to get a clearer idea of what makes the extra dimensions "spatial". Do you have to be functioning in a higher-dimensional space to begin with, like a Hilbert space, to recognize these dimensions as spatial? (BTW, I don't really understand HIlbert spaces, other than thinking they are not restricted to 3 dimensions.) Kea, I expect your answer would be that the extra dimensions aren't spatial. EL, (and anyone else who's interested) I'm curious what you would say about the above questions. |
| Nov4-06, 08:12 AM | #16 |
| Nov4-06, 08:16 AM | #17 |
I assume this wasn't directed at me. I'm here to admit the limits of my knowledge, and I'm unlikely to know if you get something wrong. Everybody else - please correct EL if he's got it wrong.
| New Reply |
| Thread Tools | |
Similar Threads for: Extra Dimensions in String Theory
| String Theory: 6 extra dimensions | Beyond the Standard Model | 30 | ||
| Why String theory has so many dimensions | Beyond the Standard Model | 1 | ||
| String Theory in Only 4-Dimensions | Beyond the Standard Model | 2 | ||
| book recommendation about string theory and extra dimensions | Beyond the Standard Model | 3 | ||
| How do dimensions in string theory interact? | Beyond the Standard Model | 2 | ||
