Toy Cannon: Calculating the Projectile Speed
The discussion centers on calculating the projectile speed of a toy cannon that uses a spring to launch a 5.30g rubber ball. The spring constant is 8.00 N/m, and the spring is compressed by 5.00 cm. The friction force between the ball and the barrel is 0.0320 N, and the ball travels 15.0 cm through the barrel. The correct formula to use is mv²/2 = kx²/2 - fk(x), which yields a projectile speed of 1.40 m/s, correcting the initial miscalculation of 1.17 m/s.
  • Understanding of Newton's laws of motion
  • Familiarity with spring mechanics and Hooke's Law
  • Basic knowledge of kinetic and potential energy equations
  • Ability to perform calculations involving friction forces
  • Study the principles of energy conservation in mechanical systems
  • Learn about the effects of friction on projectile motion
  • Explore advanced spring dynamics and their applications
  • Investigate the impact of different materials on friction coefficients
Students in physics, hobbyists building toy cannons, and educators teaching mechanics concepts will benefit from this discussion.
Dorothy Weglend
A toy cannon uses a spring to project a 5.30g soft rubber ball. Spring is compressed 5.00 cm, k=8.00 N/m. Barrel is horizontal.
The ball moves 15.0 cm through the barrel, with friction force of 0.0320 N between thebarrel and the ball. With what speed does the projectile leave the barrel of the cannon?
I thought this problem was simple, but the answer 'in the back' is different from what I am getting, so I thought I would ask for some help.
I use
mv^2/2 = kx^2/2 - fk(x+d)
x = compression of spring, d = distance along the barrel, so
m = 5.32 * 10^-3 m,
k = 8 N/m
x = 0.05 m
k = 8 N/m
fk = 0.032 N
d = 0.15 m
With these figures, I get v = 1.17 m/s.
The answer in the back is 1.40 m/s.
Can anyone see where I am going wrong?
Dorothy
Are you sure you are supposed to use ... - fk(x+d)?
if you use mv^2/2 = kx^2/2 - fk(x) instead, it will give a v of 1.40 m/s
I think the problem was trying to help you-it gave you the TOTAL distance the projectile has to travel in the barrel. I tried to make a diagram below, I'm not sure it worked.
Oh, and you meant m=5.30 x 10-3 kg right?
/\/\/ is the compressed spring
X is the projectile...|-0.15m-|
/\/\-X---->
That makes sense. Thanks. Yes, I used 5.30E-3.
Thanks again,
Dorothy
  • · Replies 21 ·
