Find First Term and Common Ratio of Geometric Progression | Step-by-Step Guide
  • Thread starter Thread starter gunblaze
    Geometric
The discussion focuses on finding the first term and common ratio of a geometric progression given the sum formula, S_n = 6 - 2/(3^(n-1)). The correct interpretation of the denominator is crucial; it should be 3^(n-1) rather than 3^n - 1. The first term (a) can be derived by substituting n=1 into the sum formula, yielding a = 6 - 2. Additionally, the sum of the first two terms provides a second equation, a + ar = 6 - 2/3, which can be solved to find both a and r definitively.
  • Understanding of geometric progressions and their properties.
  • Familiarity with algebraic manipulation and solving equations.
  • Knowledge of summation formulas for geometric series.
  • Basic calculus concepts related to limits (optional for deeper understanding).
  • Study the derivation of the sum formula for geometric progressions.
  • Learn how to solve systems of equations to find unknowns.
  • Explore the implications of changing the common ratio on the progression.
  • Investigate applications of geometric progressions in real-world scenarios.
Students, educators, and anyone interested in mastering geometric progressions and their applications in mathematics.
gunblaze
ok, the qn goes like this..
Find the first term and common ration of a geometric progression if the sum to n is given by
6 - 2/(3^(n-1))
I tried solving by making both terms of the eqn having the same denominator by multiplying (3^(n-1)) to the first term 6 and then by taking out the 2, i am able to make the formula to 2(3^n - 1)/ (3^n-1). But what about the denominator, i remember that there must be no n at the bottom. Only r - 1 where in this case, r is to be found..
Anyone out here can give me some guide? Thanks for any help given.
First, you have written that wrong. The denominator is not 3^n- 1, it is 3^(n-1). You should have
[tex]\frac{6(3^{n-1})- 2}{3^{n-1}}= 2(3^n- 1}{3^{n-1}[/tex]
But it's really not necessary to use a general formula. Since you only need to find two numbers, a and r for the general term arn, you really only need two equations. The first term, with n= 1, is a. The formula you are given says it must be
[tex]a= 6- \frac{2}{3^{1-1}}[/tex]
The sum of the first two terms, with n= 2 is a+ ar and so
[tex]a+ ar= 6- \frac{2}{3^{2-1}}[/tex]
Can you solve those two equations for a and r?
