Q:What is the analogue of the excitation vector in the case of mass density?
Mass density is identified as a 3-form, analogous to electric charge density, with its exterior derivative being zero. This leads to the existence of a corresponding 2-form, termed "excitation" (D), which relates to electric charge density through Gauss's law, one of Maxwell's equations. In fluid dynamics, there is a need to establish counterparts for these equations, particularly for the magnetic excitation field (H), which is a 1-form field. The discussion raises questions about the application of these equations in fluid dynamics, specifically referencing equations (3.1) and (3.2) from the provided arXiv link.
  • Understanding of 3-forms and 2-forms in differential geometry
  • Familiarity with Maxwell's equations, particularly Gauss's law
  • Knowledge of fluid dynamics principles and continuity equations
  • Basic concepts of electric charge density and mass density
  • Research the application of Maxwell's equations in fluid dynamics
  • Study the continuity equation in the context of fluid dynamics
  • Explore the mathematical framework of differential forms in physics
  • Investigate the implications of magnetic excitation fields in fluid dynamics
Physicists, fluid dynamicists, and researchers interested in the intersection of electromagnetism and fluid dynamics, particularly those exploring theoretical frameworks and mathematical analogies between these fields.
mma
Mass density is a 3-form, just like electric charge density. Hence it's exterior derivative is 0. This implies that there is a 2-form whose exterior derivative is the density 3-form. If this density is the electric charge density, then the name of this 2-form is "excitation" (D). But what is the name of it in the case when we speak about mass density instead off electric charge density? And where is it used?
Of course the above mentioned D excitation is the electric excitation (other name of it is electric displacement field). The equation which states that the exterior derivative of the electric excitation is the electric charge density is the so-called Gauss-law, and this is one of 4 the Maxwell's equations. And this equation must have a counterpart in fluid-dynamics, where the mass density plays the role of the electric charge density in this equation.
Moreover, there is another Maxwell's equation what must have a counterpart in fluid-dynamic. This is the Oersted-Ampere law. This equation follows directly from the continuity equation and from the Gauss-law. Regarding that both equations are valid not only in electrodynamics but in fluid-dynamics also, there must be a corresponding equation in fluid-dynamics, i.e. there must be a counterpart of the magnetic excitation field (H) also (this is an 1-form field).
Does anybody use these equations and quantities in fluid-dynamics?
I mean eqations (3.1) and (3.2) in http://arxiv.org/abs/physics/0005084"
  • · Replies 0 ·
  • · Replies 23 ·
