| Thread Closed |
Jumping inside a moving train... |
Share Thread | Thread Tools |
| Nov11-06, 03:03 AM | #1 |
Why when you jump inside a moving train you land exactly in the same place, instead of landing closer to the tail of the train?
I know it a stupid question but Im not able to find what physical law applies in this case. Has it something to do with momentum cancellation? (I remember the question about firing a bullet backwards at 1km/sec on a train going forward at the same speed) Links are welcome, thank you. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov11-06, 07:42 AM | #3 |
all that is in the reference to the ground the train is moving on. usually, i would explain it otherwise, but those new to this concept always refer motion to the ground... |
| Nov11-06, 08:29 AM | #4 |
How come when the train stops suddenly you go flying forward?
| Nov11-06, 08:38 AM | #5 |
Mentor
| Nov11-06, 09:39 AM | #6 |
But if the train is accelerating, when I am in the air after jumping, will I land in the same place?
| Nov11-06, 09:42 AM | #7 |
| Nov11-06, 09:46 AM | #8 |
I think I will land somewhere backwards, there's no force acting on me so the train during that time is traveling faster than me. But I could be wrong, that is why I asked.
| Nov11-06, 09:53 AM | #9 |
[tex]s =-\frac{1}{2}at^2[/tex] |
| Nov11-06, 10:09 AM | #10 |
I am trying to prove that a bug can come into your window while you are driving
at 60 mph and hit you. Is there a physical law to explain this as a fact? |
| Nov11-06, 10:19 AM | #11 |
Pretty straightforward.
The bug had a velocity relative to the ground of between 0 and 5mph. You had a velocity of 60 mph. mmmPOW! Seriously, the folly here is to use the jumping passenger on a train as an analogy. They're not the same. That the bug was stationary wrt ground, not wrt your car. As it enters your car window, it does not instantly accelerate to the speed of the car. Thus, when it hits you in the face, it is with a relative v of ~60mph. |
| Nov11-06, 11:22 PM | #12 |
Thank you, and I did understand that they were two different scenarios...just thought that the subject was similar enough to find an answer among the participants. More specifically though, would there be an angle of entrance imperative as the difference in speed was so drastically different? Would the draft created by the vehicle come into play? Playing devil's advocate, would it not more likely pass by the vehicle rather than enter it?
| Nov12-06, 07:30 AM | #13 |
i would imagine it would be hard for the bug to enter the car since the air inside would have a higher velocity wrt the air outside and effectively be like a wall, similar to if u use a leaf blower to blow a tennis ball in the air, it stays relitively in the same place and doesnt fall out of the airflow to the side. however wrt the angle of enterance i would say it almost certainly sould have to be normal to the car since, 60mph~27.78m/s and therefore if the window is 45cm long it would have ~ 0.016s to fly in the window assuming the velocity of the bug is << that of the car and therefore if it flew alongside te car it wouldnt increase the tme by much
| Nov12-06, 03:58 PM | #14 |
So, an open window at 60mph DOESN"T cause a roaring wind inside the car? Window up, window down makes NEGLIGIBLE difference to the air flow inside the car?
Where would you say all that air is coming from? If one of those bits of air happened to have a bug in it, what would you feel then? |
| Nov16-06, 04:08 PM | #15 |
If you was on top of the train with very little wind would the same laws apply as being inside the train?
| Nov17-06, 01:14 PM | #16 |
Hi,
you didn't mention which way the train does move. As for my experience you will not land on the same place when the train moves, but closer to the tail as the train moves forward. Steve |
| Nov17-06, 01:51 PM | #17 |
That 'experience', however, would involve air resistance if the train was moving fast enough for relative motion to be noticeable (unless there was a tail-wind that matched the train's speed).
| Thread Closed |
| Thread Tools | |
Similar Threads for: Jumping inside a moving train...
| Jumping while on a moving bus | General Physics | 10 | ||
| inclined ramp inside an accelerating train | Introductory Physics Homework | 5 | ||
| About a bee flying inside a moving train | Introductory Physics Homework | 26 | ||
| A bus is moving and lots of ppl jumping | Introductory Physics Homework | 2 | ||
| Person-jumping-out-of-a-moving-boat problem | Introductory Physics Homework | 3 | ||
