Dipstick problem (volume of a cylinder)
  • Thread starter Thread starter dipique
    Cylinder
The discussion revolves around calculating the height of fluid in a cylinder using a dipstick, specifically focusing on a circle with a radius of 5 bisected by the y-axis. The objective is to determine how far to move the circle down the y-axis to achieve specific percentages of the circle's area below the x-axis, such as 10% and 20%. A proposed solution involves creating a triangle connecting the center of the circle to the intersection points with the x-axis, allowing for the calculation of the area beneath the x-axis by subtracting the triangle's area from the wedge formed by the circle. The user ultimately finds the answer but seeks further assistance with the trigonometric calculations involved.
  • Understanding of basic geometry, specifically circles and areas.
  • Knowledge of trigonometry, particularly in relation to triangles and angles.
  • Familiarity with the concept of area calculation for circles and triangles.
  • Ability to visualize geometric shapes in a coordinate system.
  • Study the properties of circles and their areas, focusing on formulas for calculating areas above and below axes.
  • Learn about trigonometric functions and their applications in geometry, particularly in calculating angles and areas.
  • Explore methods for calculating the area of a segment of a circle, including the use of integrals.
  • Investigate geometric transformations, specifically how moving shapes affects their properties in a coordinate system.
Students and educators in mathematics, particularly those studying geometry and trigonometry, as well as engineers and anyone involved in fluid dynamics or related fields requiring geometric calculations.
dipique
There is a problem I'm doing that I understand except for one part. There is a cylinder lying flat, and I want to measure the percentage of fluid in the cylinder by lowering a dipstick inside. In order to do this, I need to find out the height of the fluid when the cylinder is 10% full, 20% full, etc. Here is the question for the part of the problem I can't do:
There is a circle with a radius of 5 bisected by the y-axis. If we move it up and down the y-axis, different percentages of the circle will be above and below the x-axis. What I need to find out is how to relate the percentage below/above the x-axis (either would work) to the distance between the bottom of the circle and the x-axis.
So: we'll start with the circle sitting right on top of the x-axis. 100% of the circle area is above the x-axis. If we want to move it down so that 10% of the circle's area is below the x-axis, how many units would the circle have to be moved down?
Dan
I just got an idea, but I don't think I know enough to make it work. One solution (I think) is to create a triangle connecting the center of the circle with the two points where the x-axis intersects the circle. That angle forms both a wedge of the circle and a triangle; subtract the triangle from the wedge, and there is the area beneath the x-axis. Since we knew the radius of the circle, finding the percentage would be simple. Unfortunately, I'm not good enough with trig to push this through. Help?
All right, I got the answer. If anybody finds this and can't figure it out, feel free to shoot me an e-mail.
Dan
