Find axis to minimize moment of inertia
The discussion revolves around finding the axis that minimizes the moment of inertia for a system consisting of two masses connected by a massless rod. Participants explore the implications of the moment of inertia formula and the conditions under which it is minimized.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of moment of inertia and its dependence on the axis of rotation. There are attempts to understand why the axis should be placed at a specific location and how to apply the parallel-axis theorem. Questions arise about the contributions of each mass and the implications of their positions.
The discussion is active, with participants providing hints and exploring different methods to approach the problem. Some participants suggest intuitive reasoning based on physical principles, while others delve into mathematical formulations. There is no explicit consensus yet, but various interpretations and approaches are being examined.
Participants are navigating the complexities of moment of inertia calculations, including the need for clarity on the definitions and assumptions regarding mass distribution and axis placement. The discussion includes references to specific formulas and the relationship between the axis of rotation and the center of mass.
vu10758
Two masses (M1 and M2) are connected by a thin massless rod of length L.
a) Determine the location of an axis perpendicular to the rod) which minimizes the moment of inertia of the system.
The answer is "with M1 at the origin x = M2*L/(M1+M2)
I know that I = Sum of ( M1*r1^2)
However, how do we know that M1 is at origin? I know that M1 + M2 is the total mass of the system. I know L is the length between the two points. But I don't know why the answer is above. I think I am missing something in understanding this but I don't know what.
b) Verify that the moment of inertia about this axis can be obtained by determine I about an axis through M2 and then using the parallel-axis theorem.
I know that I = I_cm + Mh^2 , where h is the distance between the axis, M is the total mass (M1+M2). Is the distance between the axis L? How do I use this to verify the moment of inertia.
for part a)
Hint --
How would you calculate the inertia of the system if the system was rotated about some known position -- say a distance "x" down the rod from the mass M1?
Wouldn't I use the formula I = Mx^2 then where x is the distance down from the rod?
Not quite -- what do you mean by "M"... are both masses contributing?
Ok there's two ways you can do this. First is intuitively. The moment of intertia is effectively a measure of mass for rotational motion. So if you have your axis straight through the middle of the rod, you can picture just through everyday experience that its going to require a fair bit of effort or torque in order to spin it. If you have the rod through one of the masses, the torque required to spin that object is virtually nil (t = fd and if d is some infintesimle radius...) And the only major force drain is the other mass at the max length. As I am sure you'll see from the answer you have there, if the masses are equal its best to have it in the middle, if ones larger its best to have the axis closer to that one, or through it.
This can also be solved mathematically. You have written one definition of I but there's another, more useful (for me anyway) term.
[tex]I = \int r^2dm[/tex]
Now this more general form is more for complex objects and so your sumation one is actually better for this point particle problem, but its a good idea to keep the above one in mind. Your moment of inertia is going to be
[tex]I = r^2M1 + (L-r)^2M2[/tex]
right? From your calculus classes you know that if you want to minimize a function you can differentiate it and equate to zero. Bobs your uncle :)
-G
For part 2,
I know that I = I_cm + mh^2, where h is the distance between the axes. So is h, L-r in this case? How can I get I about an axis through M2.
Is it
I = M2*L^2 + M1*(L-r)^2 ?
It is my recollection that the min. I is that axis which is the same as the centor of mass. Am I right?
  • · Replies 28 ·
  • · Replies 40 ·
