Static Equilibrium force problem
The discussion revolves around a static equilibrium problem involving forces acting on a chicken and a woman performing a push-up. The participants explore the balance of forces and torques in these scenarios.
  • Mixed
  • The original poster attempts to understand how to balance horizontal and vertical forces, questioning the relationship between torque and force directions. Other participants suggest considering additional forces that may be acting on the system.
The discussion is ongoing, with participants expressing confusion and seeking clarification on the forces involved. Some guidance has been offered regarding the identification of forces, but no consensus has been reached on the specific calculations or methods to apply.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use to solve the problems presented.
music_man05
What force must be exerted by the wind to support a 2.5 kg chicken in the position where one leg is touching the ground 9 cm from the center of mass, the other is up in the air Irrelevant to this problem.
I know the sum of the torque must be equil to zero, but if the force due to the wind is horizontal and the other forces are vertical..can they be set equal to each other? how?
There should be at least 4 forces:
Gravity
The Normal Force
Friction
Wind
I'd guess you forgot one or two of them.
I am still lost in this problem and have another for you
The same topic...
a) What force must the woman in the figure above exert on the floor with each hand to do a push-up? Assume that she moves up at a constant speed.
Fhand =
147N
b) The triceps muscle in the back of her upper arm has an effective lever arm of 1.75 cm, and she exerts force on the floor a horizontal distance of 20 cm from the elbow joint. What is the force in her triceps muscle?
Fmuscle =
  • · Replies 42 ·
