Where can I find massless string for physics experiments?
  • Context: High School
  • Thread starter Thread starter l_tunaboy
    Massless String
The discussion revolves around the search for massless string for physics experiments, with participants exploring the concept of massless materials in experimental contexts. The scope includes practical suggestions for alternatives and humorous takes on the terminology used in physics.
  • One participant inquires about purchasing massless string for physics experiments, acknowledging its rarity.
  • Another participant humorously notes that a massless string would have zero volume and diameter, making it indistinguishable from an empty envelope.
  • Some suggest alternatives like 'invisible thread' used by illusionists or dental floss, which has negligible mass.
  • A participant questions the practicality of weighing something that is massless, prompting further humorous exchanges.
  • Concerns are raised about the implications of using massless string in experiments involving standing waves, suggesting it could complicate the experiment.
  • One participant mentions that all string is effectively massless within experimental uncertainty unless using highly precise instruments.
  • Another participant jokes about buying massless string alongside frictionless pulleys, adding a light-hearted tone to the discussion.
Participants express a range of views on the concept of massless string, with some suggesting practical alternatives while others engage in humorous banter. There is no consensus on the definition or availability of massless string, and the discussion remains unresolved regarding the best approach to the original inquiry.
The discussion highlights the ambiguity in the term "massless" and its implications for experimental design. There are unresolved assumptions about the precision required for the experiments mentioned.
l_tunaboy
Hi,
I am new to the forum. lol.
I came here because in my physics class, many of the experiments call for massless string.
Does anyone know where I could purchase some?
I understand it is harder to come by, but I am willing to pay extra.
Thanks a bunch
But beware! A massless string must have zero volume and therefore zero diameter, unless there is a substance that has zero density. Therefore an envelope containing a massless string is difficult to distinguish from an empty envelope. :wink:
Yeah. Someone is either having you on, or using bad terminology.
The closest thing that I can think of to what you want is actually called 'invisible thread'. Close-up illusionists use it to levitate things like cigarettes or coins. Any magic-supply house will have it in stock.
We Norwegians sell tons of it to dumb Swedes.
Just how does one weigh out 'tons' of something with no mass? :confused:
Good question! But then, you are a Canadian, not a Swede.
Sad, but true :frown:
That might explain it...
l_tunaboy said:
Hi,
Thanks a bunch
Try dental floss. It's strong and has a mass of nearly zero, except for particularly large values of zero.
It's also works very well to cut cake at parties.
Picturing that really made me laugh. :smile:
l_tunaboy said:
Hi,
Are you using a precision microgram torsion balance? If not, all string is massless to within experimental uncertainty. That's what "massless" means in this context.
lol, if you are looking for string with very insignificant mass, try fishing line or as danger pointed out, magicians string (or whatever you call it). I doubt that the mass of a string is going to ruin your experiments unless you're using shoe laces, and even in that case you could weigh it beforehand and subract it from your experimental data.
What's so funny about that?
Measure out the needed length of floss and dip it in a cup of water. Then you can visually lay out your cut, holding the floss over the cake, then lowering it as you slightly bring the string back towards your body. Perfectly straight cuts without that tendency to veer off to one side that frequently happens as you concentrate on the point where the knife is contacting the cake.
If the poster has access to such a balance I suspect they would not have had to ask the question...:rolleyes:
I looked at the post thinking it was about string theory!
l_tunaboy said:
Hi,
Thanks a bunch
I hope your experiment isn't on standing waves on a string. A massless string would tend to complicate your experiment.
On the other hand, that would provide one way to measure the mass of your string if you lacked a scale of sufficient precision.
Why bother about them when we can partake in the glory of the Atwood machine? :confused:
l_tunaboy said:
Hi,
Thanks a bunch
:smile: :smile: I think you can buy them at the same place the sells the frictionless pulleys. :approve:
Oh, and from your username, it seems you'll probably really enjoy our current welcome fish...mackerel! :biggrin:
Thanks everyone for the help.
I guess that my precision microgram torsion balance experiments will have to be put on hold.
For now, floss it is.
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 0 ·
  • · Replies 47 ·
10K
10K
