How Do You Calculate Arc Length and Angle Measurements in Circular Motion?
The discussion focuses on calculating arc length and angle measurements in circular motion. A protractor with a scale of 7.5 cm from the center point raises questions about the spacing of degree marks, leading to the realization that the calculation is not simply 360/7.5. Additionally, the problem involving a 12-inch diameter phonograph record confirms that a quarter turn corresponds to π/2 radians, while the arc length for a point on the rim requires understanding the circumference formula.
  • Understanding of radians and degrees in angular measurement
  • Knowledge of the circumference formula: C = 2πr
  • Familiarity with circular motion concepts
  • Basic geometry skills related to circles
  • Study the relationship between degrees and radians in detail
  • Learn how to calculate arc length using the formula: Arc Length = rθ
  • Explore the properties of circles, including diameter and radius
  • Investigate applications of circular motion in real-world scenarios
Students studying geometry, physics enthusiasts, educators teaching circular motion concepts, and anyone needing to calculate angles and arc lengths in practical applications.
8parks11
A protractor is made so that the edge of its scale is 7.5 cm from the center point. If the scale is marked in degrees, how far apart are the marks along the edge?
I just thought this would be 360/7.5 but it's not. I'm not sure If I got the question correct.
A 12-inchdiameter phonograph record rotatesaboutits center by one-quarter turn. a) Thorugh how many radians has it turned? b) How far has a point on the rim moved?
For a, I got pi/2 which I think iscorrect, but for b, I don't know what to do...
can i get some help?
What is the circumference of a circle in terms of its radius?
  • · Replies 20 ·
