Basic Homework Help: Solving Problems with Compressed Air and Diffusion
  • Thread starter Thread starter merrymanjane
    Homework
The discussion revolves around two problems related to the behavior of compressed air and diffusion. The first problem involves calculating the number of air molecules released from a tank as pressure decreases, while the second problem concerns the time it takes for a perfume molecule to diffuse a specific distance in still air.
  • Participants discuss the application of the ideal gas law (PV = nRT) to determine the number of moles of air before and after the release. There are questions regarding the appropriate units for pressure and the gas constant R. Some participants suggest using different values for R based on the pressure units chosen.
The discussion is ongoing, with participants providing guidance on the formula to use and the necessary conversions. Multiple interpretations of the problem setup and the constants involved are being explored, but no consensus has been reached yet.
Participants are navigating the specifics of unit conversions and the assumptions regarding the conditions of the gas and diffusion processes. There is an emphasis on ensuring the correct application of the ideal gas law in the context of the problems presented.
merrymanjane
Can anyone help me solve these two problems?
1. A tank of compressed air of volume 1.0 m^3 is pressurized to 40 atm at T= 273. A valve is opened and air is released until the pressure in the tank is 23.0 atm. How many air molecules were released?
2. About how long will it take a perfume molecule to diffuse a distance of 7.00 m in one direction in a room if the diffusion constant is 1.00 x 10^-5 m^2/s? Assume that the air is perfectly still- there are no air currents.
Use the formula
PV = nRT
P is pressure (pascals or kilopascals, I can't remember), V is volume in litres, n is the number of moles, R is the gas constant, T is temperature in kelvin
Figure out how many moles of air molecules were there at start then how much after. Just subtract the two.
P should be in atmospheres.
Depends which R you use.
Use Pascals and 8.31 for R
  • · Replies 31 ·
  • · Replies 60 ·
