Pinball: Finding Spring Constant for Min Speed
  • Thread starter Thread starter dan_c_101
The discussion revolves around a problem related to a pinball machine involving a spring and its spring constant. The original poster seeks to determine the spring constant necessary for a ball to achieve its minimum speed to navigate the boundaries of the machine without falling off.
  • Participants discuss the application of conservation of energy in the context of the problem. There are attempts to clarify the meaning of the variables involved, particularly the spring constant and its relation to the spring's displacement. Some participants express confusion regarding the problem's statement and the minimum speed of the ball.
The discussion is ongoing with participants seeking clarification on the definitions of variables and the problem's requirements. Some guidance has been offered regarding the spring's force and its relationship to displacement, but there is no consensus on the specifics of the problem or the necessary equations.
There is a noted lack of detailed information provided by the teacher, leading to confusion among participants. The minimum speed of the ball is questioned, as well as the interpretation of the spring constant in this context.
dan_c_101
In a pinball machine, there is a spring, the further back you pull the spring the faster the ball goes. With variables, h, m, R, K and g, what is the spring constant. To get the ball at its minimum speed to go around the boundries of the pinball machine without falling.
I can't say I understand the problem completely, but I'm pretty much sure you need to use conservation of energy somehow. Hope that helps.
What my teacher is asking is basically the equation for x (spring constant). there's no numbers involved, but I am getting really confused.
While all of the variables you listed are completely understood by you, they are a total mystery to us. Please define your variables.
Also the minimum speed of the ball is 0, it will not go anywhere at the minimum speed. Please give us a better statement of the problem.
Your question appears a little vague. Generally, the spring constant is implied by the variable k (dimensions N/m) and x is the displacement of the spring (in meters) from its equilibrium point. In general, the force Fs of the spring is given by:
Fs = -kx
The negative implies the force acts in the opposite direction of the displacement. Some textbooks call this a restoring force.
If you write the entire question down, perhaps we can be more specific to your needs.
Hope this helps.
Sorry guys, this is all that my teacher gave our class. h is the height of the pinball table like from the spring to the very top of the pinball table. And there is a spring constant (i think he means the stretch of the spring) so that the ball can go at a velocity that would get it around the boundaries of the pinball table without falling off its path. Sorry I can't be more detailed but that's all the info we were given. m is mass, x is spring constant, g is the acceleration.
Your looking for how far does the spring stretch back, not the constant.
