Calc Change in Internal Energy of Boiled Water
The problem involves calculating the change in internal energy of 1 kg of water at 100 degrees Celsius as it transitions to steam at the same temperature, while maintaining constant pressure at 1 atm. The discussion includes considerations of heat transfer and work done during the phase change.
  • Mixed
  • Participants discuss the calculations for heat (Q) and work (W), with some questioning the accuracy of the original poster's values and conversions. There is also a focus on ensuring the correct units are used in the calculations.
There are multiple interpretations of the calculations presented, with some participants suggesting corrections to the work done (W) calculation. The conversation is ongoing, with no explicit consensus reached on the final values.
Participants are working within the constraints of homework guidelines, which may limit the depth of discussion. There is an emphasis on significant figures in the final answers.
cowgiljl
Seem to have ran into a brick wall with this problem
Determine the change in internal energy of 1 kg of water at 100 degrees C when it is fully boiled. Once boiled this volume of water changes to 1671 Liters of steam at 100 degrees C Assume the pressure remains constantat 1 atm
things i know
1 L =1E-3 m3
1atm = 1.013E5 N/m2
1 L = 1000 cm3 = 1E-3 m3
formulsa used
Q=mLv = 1kg*2.26E6 J/k Q=2260000 J
W = -P(Vsteam-Vwater) = (1.013E5)*[(1671000 - 1000)*.001
W = -169171E3 J
change in U = Q+W
2260000-169171000
U = -166911E3 J
If i did make a mistake i think it is where W is .
Thanks Joe
Hmm... I can't remember if your calc. of Q is
correct but as far as W goes, if memory serves right,
I believe the conversion should be 1 Atm*Liter = 101 Joule,
and then you get:
W = - P * dV = - 1 (Atm) * (1671-1) (Liter) =
= -1670 * 101 J = -168670 J
Live long and prosper.
W = -169171E3 J
In your equation, you have the volumes in cubic cm instead of liters. You should have:
W = -P(Vsteam-Vwater) = (1.013E5)*[(1671 - 1)*.001]
(This is consistent with drag's calculation.)
Also, 3 significant figures in your answer is plenty.
Now if my Q is right and I use drags and Doc Als conversion then U is equal to 2.09E6 J
is that correct
these were some of the homework questions i didn't finish
Thanks a lot
Joe :smile:
14K
