Curl and Cauchy-Riemann Conditions problem
  • Thread starter Thread starter Saketh
    Conditions Curl
The discussion centers on verifying the Cauchy-Riemann conditions for a two-dimensional incompressible and irrotational flow represented by the velocity vector \textbf{V} = \textbf{i}u(x, y) - \textbf{j}v(x, y). The key equations to prove are \(\frac{\partial u}{\partial x} = \frac{\partial v}{\partial y}\) and \(\frac{\partial u}{\partial y} = -\frac{\partial v}{\partial x}\). The user, Saketh, successfully verified the second equation using the curl of \textbf{V} and was guided by another user, nazzard, to apply the divergence condition \(\nabla \cdot \textbf{V} = 0\) for incompressible fluids to prove the first equation. This highlights the importance of the continuity equation in fluid dynamics.
  • Understanding of vector calculus, specifically curl and divergence operations.
  • Familiarity with the continuity equation for fluid dynamics.
  • Knowledge of the Cauchy-Riemann conditions in the context of fluid flow.
  • Basic principles of incompressible fluid behavior.
  • Study the continuity equation in fluid dynamics in detail.
  • Learn about the implications of the divergence theorem in fluid flow.
  • Explore the relationship between irrotational flow and potential functions.
  • Investigate applications of the Cauchy-Riemann conditions in complex analysis.
Students and professionals in fluid dynamics, mathematicians focusing on vector calculus, and engineers working with incompressible fluid flow models.
Saketh
Problem
The velocity of a two-dimensional flow of liquid is given by
[tex] \textbf{V} = \textbf{i}u(x, y) - \textbf{j}v(x, y).[/tex]​
If the liquid is incompressible and the flow is irrotational show that
[tex] \frac{\partial u}{\partial x} = \frac{\partial v}{\partial y}[/tex]​
and
[tex] \frac{\partial u}{\partial y} = -\frac{\partial v}{\partial x}[/tex]​
My Work
I evaluated [itex]\nabla \times \textbf{V} = 0[/itex] through a determinant, and ended up with this expression:
[tex]\textbf{i}\frac{\partial v}{\partial z} + \textbf{i}\frac{\partial u}{\partial z} - \textbf{k}\left ( \frac{\partial u}{\partial y} + \frac{\partial v}{\partial z} \right ) = 0[/tex]​
Through this, I was able to verify:
[tex] \frac{\partial u}{\partial y} = -\frac{\partial{v}}{\partial x}[/tex]​
I could not verify the other expression. How can I verify the other expression - I've tried everything I can think of. It seems simple, but I am missing something.
Thanks in advance.
Hello Saketh,
to get
you need to use the fact that div V = 0 for incrompressible liquids.
This follows from the continuity equation:
[tex] \frac{\partial \rho}{\partial t} + \nabla(\rho\,\textbf{V})= 0[/tex]
and using the fact that the liquid is incompressible, hence the mass density [itex]\rho=const.[/itex]
Regards,
nazzard
P.S.: There's a small typo in your current solution: one \frac command is missing
Oh, I thought that incompressible just meant that the fluid flow is behaving ideally, and had no mathematical significance.
Now that you tell me [tex]\nabla \cdot \textbf{V} = 0[/tex], the answer is obvious. Thanks!
  • · Replies 19 ·
