How Do Relative Velocities Transform in Special Relativity?
  • Thread starter Thread starter wansui
    Speed Velocity
The discussion focuses on the transformation of relative velocities in special relativity, specifically addressing the speeds of objects A and B moving at 0.9c and 0.7c relative to a stationary observer E. It emphasizes the use of the velocity addition formula from special relativity to determine the speeds of A and B in each other's reference frames. The symmetry of relative velocities is highlighted, confirming that if A sees B moving at speed v, then B sees A moving at the same speed v. The discussion encourages users to utilize the provided resource for further calculations.
  • Understanding of special relativity principles
  • Familiarity with the velocity addition formula in special relativity
  • Basic knowledge of reference frames
  • Ability to interpret mathematical equations related to physics
  • Study the velocity addition formula in special relativity
  • Explore Lorentz transformations and their applications
  • Learn about time dilation and length contraction effects
  • Review examples of relative motion in different inertial frames
Students of physics, educators teaching special relativity, and anyone interested in understanding the principles of relative motion and velocity transformations in different reference frames.
wansui
If A is moving to the left at a speed of 0.9c relative to E, B is moving to the right at a speed of 0.7c relative to E.
In the reference frame of A, what is the speed of B?
In the reference frame of A, what is the speed of E?
In the reference frame of B, what is the speed of A?
In the reference frame of B, what is the speed of E?:rolleyes:
Have a look at this page:
http://www.math.ucr.edu/home/baez/physics/Relativity/SR/velocity.html
Try to see if you can answer your own questions using the equations there, and then post again if you're still having trouble. Also, note that speed in special relativity is symmetrical between any two reference frames--if in my frame you are moving at speed v relative to me, then in your frame I will also be moving at speed v relative to you.
  • · Replies 40 ·
  • · Replies 44 ·
