Thread Closed
extended essay topic question
Share Thread Thread Tools
Feb15-04, 03:18 PM   #1
i'm starting [again] a physics topic for extended essay for IB...my last few topics haven't worked due to technical difficulties [ie: can't complete experiments, lack of avaliable resources, etc] so my new idea for a topic is firearms. the lab can easily be done by going to a shooting range sometime this week.
i'm looking to have at least three comprehensive subthesis', each focusing on a field of physics that is directly relevant. my ideas for two so far are:
momentum laws - primary/secondary recoil, terminal ballistics etc, all with a few relevant equations.
gas laws - actual firing of gun, how it cycles, noise generated and how it could be reduced, might be able to get some relevent figures [ratio of gunpowder grain to gaseous products]
i dunno what to do the last one[s] on..kinematics and sound could be plasuable if i need, but are both sortof weak. so any sortof help would be great. thanks :)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Feb15-04, 07:37 PM   #2
Recognitions:
Gold Membership Gold Member
vodka, I dont have enough knowledge/ideas about rifles to help
except to dig up from memory an experiment that
a Freshman physics (like 1A or 1B) did years ago in class (!) with a 22.
I guess it was after class had ended.
there was a wooden frame like a sawhorse from which was
suspended a pendulum
and the pendulum bob was a large block of wood of known mass into which the bullet would embed itself on impact
the 22 rifle, IIRC, was clamped in a vise on the experiment bench.
an observer from the side (far enough away for safety)
could see what angle the pendulum swung
the bullet mass was determined
it was fired into the pendulum, which was hanging at rest,
the momentum imparted to the combined mass of wood block and slug
was determined from the angle of swing
the speed of the slug was calculated
perhaps this is a standard procedure
(i mention it only because it is all I got that is remotely
applicable)
BTW this seems potentially dangerous to me because the suspension of the pendulum is critical and the slug must hit dead center to avoid putting a torque on the block.
I'm not recommending this! It is just all I've seen done with firearms in first year college physics.
Feb15-04, 08:46 PM   #3
I did a similar experiment, except with an airsoft gun. It was hard to get a correct angle reading, but once I did, i was surprised by the accuracy of the experiment. The gun shot 280 FPS according to the manufacturer. My experiment found the average velocity around 260-270 FPS. Not bad!
Feb16-04, 12:03 AM   #4
on a completely tangential point, what gun do you have? ^_^
i got a mk23 socom kit and a tm mp5a4hg. it currently has a navy flashhider, clawmount, guarder 11stage RDS, 2 and 3 pt slings, 2x hicaps, 5x locaps, an ICS triplerail handgrip, mag clamp, large 8.4 3000mah battery in a case. in the process of purchasing a vertical handgrip, and looking into a better flashlight and laser pointer. i've spent so much, its obscene.
i get to spend about twice what you would for the same thing because of the stoopid importation laws in canada. ah well. least we get trademarks and unpainted barrels [:D]
Thread Closed
Thread Tools
Similar Threads for: extended essay topic question
Thread Forum Replies
IB physics extended essay HELP!! Introductory Physics Homework 3
Chemistry Extended Essay Chemistry 5
possible IB extended essay topic Introductory Physics Homework 1
Extended Essay advice Biology, Chemistry & Other Homework 4
Economics IB Extended Essay Help! Social Sciences 0
