Work, Stairstep Ball | P.E. Calculation
  • Thread starter holly
  • Tags
    Ball Work
In summary, the ball has a P.E. of two thirds of its original PE once it has lost one third of its height. This is assuming that we are referencing it's PE with respect to the floor (bottom of the stairs).
holly
184
Okay, I have a ball balanced on a pole. The P.E. is given as 30 J. At the bottom of the pole, if it were to fall off, what would the P.E. be? I say zero. Okay, but now the ball is setting on top of a series of steps. The topmost step is the same height as the pole was, so I am guessing the ball has 30 J P.E. again. But, if it goes to the next step (three steps total, it is setting on the top one), I mean falls down to that step and sticks, is the P.E. one-third as much since it is one-third of the way down, or two-thirds as much, seeing as it is still 2/3 of the way up? It is going down, yes, but it's still 2/3 of the way off the ground. Does the 5dt^2 thing have anything to do the the ball now?
I would say that the ball has a PE of two thirds it's original PE once it has lost one third of it's height. This is assuming that we are referencing it's PE with respect to the floor (bottom of the stairs.
Remember that PE=mgh where mg is the weight (mass*gravity) and h is the height. Since it is only two third the original height, it should have only two thirds the original PE.
As for the "5dt^2 thing," I have no idea what you are talking about. Can you elaborate?
doesn't it depend on the place you take to be 'zero potential energy'? if you set it to the center of the earth, for instance, it has a long ways to go. further still if you make it the center of the galaxy =P . but if you're assuming that the bottom of the stairs is ZPE then when it is a third of the way down, it would have two thirds of the energy remaining as compared to when it started. since the equation I'm guessing youd use is Ep = mgh, m and g are constant [cuz i doubt the changes from e = mc^2 and g = Gm/r^2 would make a difference :) ] so h is the only factor that really makes a difference here. h' is two thirds h, [or, it still has two thirds of the distance to fall] the energy at that point is also 2/3. did that help any? ^^
and i don't know about that 5dt^2 equation you're referring to, sorry :(
Originally posted by holly
... two-thirds as much, seeing as it is still 2/3 of the way up? It is going down, yes, but it's still 2/3 of the way off the ground...
that seems quite reasonable to me
it has 2/3 as much altitude so it must
have 2/3 as much PE
anyone see a flaw in that?
Personally I don't see how the 5dt^2 thing is relevant since yr not being
asked about the time it takes to fall
only the change in PE
edit: I think what holly means by the 5dt^2 thing is that
the distance something falls in time dt is
about 5 meters per second2 times the square of the time it has been falling----(dt)2
but the problem does not involve calculating the falling time, dt, or calculating anything else from the falling time. so that formula plays not role.
paul, vodka,
what do you bet she will be back with another question
I think it is better than even odds.
i think i did more difficult stuff in grade 10 and should move my question in the k-12 forum into this one so it'll get attention [honors physics class, cover first/2nd year university stuff anyways] :wink:
Youse are getting mean.
Thank you for the help given.:frown: I won't ask more questions.
why?
I was hoping you would!
didnt realize we were mean sounding
for goodness sake holly, nobody meant to sound mean
we all like getting physics problems questions
if you have more it would be shame not to ask them!
BTW where did you find the remake of the quote from
a Famous Physicist, it is a very funny take-off of what
he said (in all his false modesty) about seeing more
than others because he stood on giants shoulders.
indeed, no offence intended sorry [b(]
and even if we did, by listening to us you'd just be hurting yourself since you wouldn't be using such a valuable asset. i think its about as much fun to give help as it is to get it and i'll be damned if i don't need help right now...
hmph...I wouldn't blame anyone for being tired of my stupid questions. I am so sick of not understanding, embarrassed, too.
I made up the take-off on Newton's remark. Ha ha, it's how I feel.
Thanks for answering the questions.
Glad to see you are back.
Don't be embarrassed about not understanding. If everyone understood, this forum would not exist. We all have something we get stuck on. I am glad to have found this forum, and I have had a few questions answered so far.
So, is this question you originally posted answered for you? If not, what are you still not clear about? I just completed my own physics HW (for now anyway), and I will check back here later (after the kids are asleep).[zz)]
Catch you later.
Thx, I think I understand about the ball's P.E. now. I guess gravity didn't have anything to do with the problem, not sure why I thought it did. Oh, well.
holly the problem has to do with gravity
the potential energy you are dealing with is called gravitational potential energy
gravitational PE = mgh = mass x 10 m/s^2 x height
it is proportional to the height
there is more than one formula involving gravity
the
distance fallen = (1/2)g (time)^2
formula is one that involves falling-time
but it is not the only one
holly,
in every introductory physics course
there is a certain goal of what to teach
out of several possible formulas about gravity, the teacher and the t textbook writers may have chosen just two gravity-formulas for you to learn how to use
(or they may have three, with one about a cannonball flying in a parabolic arc, or they may have more---there are several they can choose)
let's you and me suppose the simplest, that they just want you to learn a mere TWO gravity formulas
those two would be the same the world over but the symbols vary,
the two formulas (partly in my crude personal symbols) would be
DISTANCEFALLEN = (g/2) TIME2
and
POTENTIALENERGY = MASS g HEIGHT = mgh
and this little gee symbol stands for g = 10 meter per second2
so naturally one half of gee = (g/2) = 5 meter per second2
If the problem involves work done to rais something, measured in joules, then you use the second formula.
If the problem involves the time it takes (measured in seconds) for something to fall a certain distance (measured in meters) then you use the first formula.
You must make a list of all the formulas you are expected to know how to use. For a one-semester class this will normally take one side of one sheet of typing paper.
(However if it is CalTech or MIT it may take both sides)
You must memorize, together with the formula, the circumstances in which you use it.
You must say this over to your self at least once a week until the final exam is over.
You can use this PF message board to develop your list, with us to help, if you wish.
the list that a freshman in college physics accumulates in one semester is apt to be much the same wherever you go even like
Romania or Bangladesh but certainly in Texas
we have all been thru this, and it ultimately turns out to be fun
1. How does the stairstep ball work?
The stairstep ball is a type of exercise equipment that consists of a ball with multiple steps on its surface. The user stands on the ball and steps up and down, similar to climbing stairs. This movement engages the leg muscles and provides a cardio workout.
2. What are the benefits of using a stairstep ball?
Using a stairstep ball can provide a low-impact, full-body workout. It can improve cardiovascular health, increase muscle strength and endurance, and help with balance and coordination. It is also a convenient and affordable option for at-home exercise.
3. How do I calculate the P.E. (Potential Energy) of using a stairstep ball?
The P.E. of using a stairstep ball can be calculated by multiplying the mass of the user by the acceleration due to gravity (9.8 m/s^2) and the height of the steps. This calculation can give an estimate of the energy expended during the exercise.
4. Is using a stairstep ball suitable for all fitness levels?
The intensity of using a stairstep ball can be adjusted by changing the height of the steps and the speed of stepping. This makes it suitable for people of different fitness levels. However, it is always recommended to consult with a doctor before starting any new exercise routine.
5. Are there any safety precautions to keep in mind while using a stairstep ball?
To ensure safety while using a stairstep ball, it is important to have a stable and non-slip surface for the ball. It is also recommended to use a spotter or handrails for balance, especially for beginners. It is crucial to start slowly and gradually increase the intensity and duration of the workout. Proper form and posture should also be maintained to prevent injury.
