Calculating Volume Using Spherical Coordinates | Sphere & Paraboloid
The discussion revolves around calculating the volume of a region bounded by a sphere defined by the equation x² + y² + z² = 2 and a paraboloid given by z = x² + y², using spherical coordinates. Participants are exploring the appropriate limits for integration in this context.
  • Participants discuss the conversion of the equations into spherical coordinates and the setup of the volume integral. There are questions about the limits of integration for the spherical coordinates, particularly for the variable ρ (rho) and the angle φ (phi). Some participants suggest dividing the integral into parts based on the surfaces involved.
There is an ongoing exploration of the problem with various interpretations of how to set up the integral. Some participants are questioning the necessity of splitting the integral into two parts, while others are considering the implications of the surfaces intersecting at specific points. Guidance has been offered regarding the integration order and the use of trigonometric identities.
Participants note that the problem involves specific constraints related to the geometry of the shapes and their intersections, particularly at z = 1. There is also mention of previous experiences with similar problems, which may influence their current understanding and approach.
robierob
I need to use spherical coordinates to try and find the volume of the region bounded by
x2 + y2 + z2 = 2 which converts to p=Sqrt.(2) a sphere
and
z = x2 + y2, a parabloid which I converted to cot(phi)csc(phi)=p
I hope the greek letters for these are comonly used
x=psin(phi)cos(theta)
so far I have
V=SSS (p^2)sin(phi) dp d(theta) d(phi)
i know that theta goes from 0 to 2pi but how do I find the other limits?
Well, think a little about what this shape looks like. It's all in the "upper" half of the universe, so it's not surprising that you can use limits of 0 and pi for phi. As for rho... you'll actually have to divide the integral into two parts: one that starts at 0 and terminates on the sphere, and one that starts at 0 and terminates on the parabloid.
Make sense?
The part about spliting it into two intergrals doesn't really make sense to me. I have seen the solution to a similar one with a cone instead of a parabloid and it was done with one triple intergal not two added togreather. That's what you mean right?
Some, you can do with a single triple integral... this one, you have to divide into two pieces, by phi. Well, if you want to say that the upper limit of rho is min(sphere, parabloid), I suppose that's just one integral. But offhand, it seems to me that you need to find the value of phi where this minimum changes from one surface to the other.
I'll ask again... you've thought about what this region looks like, right?
In the case of a cone instead, you never have a case where an upper limit for rho of min(sphere, cone) is ever the cone, so you have a single integral. :smile:
(Also, I want to make clear that I'm talking about the rho component of the sphere, cone and parabloid here, and I'm too lazy to use proper tex notation and subscripts.)
When I started out on this problem I attempted to use cylindrical coordinates.
The set up looked nice but integrated, no so nice
V=SSS rdzdrd(theta)
z from r^2 to rt. (2-r^2)
r from 0 to 1
and theta from 0 2pi
but when I got to integrating with respect to r it got weird, mabey a trig sub could be used. I don't know.
anyways, i have graphed it and know what it looks like.
I know that they intersect when z = 1
I just don't see p or rho coming into the picture. I know rho is cot(phi)csc(phi)=rho
should I stick to cylindrical coordinate for this one?
No, I think the spherical coordinates are correct.
So, right, the surfaces intersect at z=1. What phi does this correspond to? (Do you see that for smaller phi, you integrate p (or rho) out to the sphere, but for phi larger than this, you go out to the parabloid?)
The integral isn't bad, even when the limit is the parabloid. Don't use cot and csc though, just write it as sin and cos. Do theta first, then rho, then phi. The phi integral can be tackled by converting all but one of the cosines into sines, and then substituting u=sin phi.
Ok, I am going to try and see how that works out.
Thanks
10K
