Radius / Interval of Convergence (Power Series)
The discussion revolves around finding the radius and interval of convergence for a specific power series defined as the sum from n=0 to infinity of (2-(n)^(1/2)) * (x-1)^(3n). Participants are exploring the application of the ratio test in this context.
  • Participants are attempting to apply the ratio test to determine convergence, with some expressing uncertainty about their results and whether they are interpreting the limit correctly. Questions arise about the correctness of the limit derived from the ratio test.
The discussion is active, with participants clarifying the power series expression and sharing their thoughts on the ratio test. Some guidance has been offered regarding the application of the ratio test, but there is still uncertainty about the results and the next steps.
Participants have noted potential confusion regarding the expression of the series and the specific terms involved, particularly the placement of the square root in the term (2-n^(1/2)).
student45
I need help finding the radius & interval of convergence of the following power series:
The sum from n=0 to infinity of...
I think the ratio test is supposed to work, but I narrow the limit of the test down to 1/|x-1|^3 < 1, and this doesn't make sense to me. Is there an easier way, or am I doing something wrong?
Thanks.
[tex]\sum_{n=0}^{\infty} (2-n^{\frac{1}{2}})(x-1)^{3n}[/tex]
Is this the question?
Yeah, that's the one. Is the ratio test the right approach? Is 1/|x-1|^3 < 1 the right result? I'm just not sure where to go from there, or even if that is right for the limit. Thanks a lot for your help.
Oh except that only the "n" is raised to 1/2. Not (2-n). The quantity is (2-n^.5)
Now that's right. Interval/Radius of convergence is the issue. I just don't know what I'm doing wrong with the ratio test.
Thanks.
Using the ratio test:
[tex](x-1)^{3}\; \frac{2-(n+1)^{\frac{1}{2}}}{2-n^{\frac{1}{2}}}[/tex] As [tex]n\rightarrow \infty[/tex] we get [tex]|(x-1)^{3}| < 1[/tex]
I appreciate it. Thanks!
  • · Replies 24 ·
