Pendulum's and special relativity
The discussion focuses on three problems related to pendulums and special relativity. In the first problem, the period of a pendulum in a uniformly accelerating vehicle is analyzed, emphasizing the need to determine the effective gravitational acceleration. The second problem involves calculating the speed at which an object's density, measured from a system S, is 1.088 times its proper density, revealing a discrepancy in the expected speed ratio of v/c. The third problem examines the speed at which a particle's kinetic energy equals its rest energy, highlighting a misunderstanding in equating total energy to kinetic energy. Key insights include the importance of effective gravitational force and the correct application of relativistic mass.
  • Understanding of pendulum dynamics in non-inertial reference frames
  • Familiarity with special relativity concepts, including relativistic mass and length contraction
  • Knowledge of energy equations, specifically E^2 = p^2 * c^2 + m^2*c^4
  • Ability to manipulate ratios and solve for variables in physics equations
  • Study the effects of acceleration on pendulum motion in non-inertial frames
  • Learn about the Lorentz factor (gamma) and its implications in relativistic density calculations
  • Explore the relationship between kinetic energy and total energy in special relativity
  • Review examples of relativistic mass and its impact on physical properties
Students and professionals in physics, particularly those studying mechanics and special relativity, as well as educators looking for practical examples of these concepts in action.
k4wedi
1) A mathematical pendulum , length L= 0.61 m oscillates in a uniformly accelerating vehicle. The acceleration is horizontal and equal to 3.2 m/ s^2 The period of oscillations is?
I don't know where to put in the acceleration when it is horizontal. I thought that if I just added the two vectors mg and ma I would get the answer but that turned out to be the same as if I was moving up vertically..
2) At what speed v should an object move with respect to a system S in order that its density measured from S is n=1.088 times greater then its proper density ( i.e. density measured in a system in which object is at rest ). Express your result as a ratio v/c .
I got it so that: 1.088(RestDensity) = (RestDensity) / [ 1 - (v/c)^2 ]
After working it out I got my answer to be 0.284... but the "right" answer is 0.878.. that doesn't make any sense to me since you'd have to move at almost 90% the speed of light just to increase 1.088 times your rest density??
3) Calculate the speed at which the kinetic energy of a particle is equal to its rest energy. Express your result as v/c
This.. I got it to be 0.84 and the "right" answer is 0.87..
I used E^2 = p^2 * c^2 + m^2*c^4; where m is the rest mass and p is the momentum
equated p^2*c^2 to m^2*c^4 and solved for v by subbing p = mv where the m in this case is the relativisic mass. Is that just plain wrong?
Much thanks to anyone who can help, I've been at these problems for a while.. :<
For #1 figure out where the equilibrium position will be (at an angle to the vertical) and find the "effective g" which is related to the tension in the string as viewed by an observer in the vehicle. As viewed from outside the vehicle, the horizontal component of the tension is responsible for the acceleration.
What you did for #2 seems right. I assume you are to use relativistic mass and the volume decreases because of length contraction, so your factor of gamma² looks right.
For #3 it appears you may have two problems. It looks like you set the square of the total energy equal to twice the square of the rest energy. I think what you need is (E - m_o*c²) = kinetic energy = 2*m_o*c² or E = 3*m_o*c². Unfortunately, that does not give you the "right" anser either. The supposed right answer is setting the total energy (not the kinetic energy) to twice the rest energy. That is not correct.
  • · Replies 20 ·
