Make Chlorate Fast: Should I Use DC Converter 300 AMP?
  • Thread starter Thread starter Aeed
    Cell
Using a 300 Amp DC Converter for chlorate production is not advisable due to rapid electrode corrosion and excessive chlorine gas generation. While higher currents can accelerate chlorate production, they lead to fewer residual chlorate crystals and potential damage to the electrolytic cell. Maintaining a reasonable current level is crucial to optimize production without compromising safety or equipment integrity.
  • Understanding of electrolytic cells and their operation
  • Knowledge of chlorate production processes
  • Familiarity with current density concepts
  • Safety protocols for handling chlorine gas
  • Research optimal current density for chlorate production
  • Learn about electrode materials and their corrosion rates
  • Investigate safe handling and storage of chlorine gas
  • Explore alternative methods for chlorate synthesis
Electrochemists, hobbyists in chlorate production, and anyone involved in the safe operation of electrolytic cells.
Aeed
In Chlorate cell should i run 300 Amp by DC Converter 300 AMP to make Chlorate in short period?
Chemistry news on Phys.org
i would not recommend that because the greater the current, the faster the electrodes will corrode. i also would not recommend this because the massive amount of chlorine gas it would cause.
it may speed up the process but you will have fewer chlorate crystals left over.
But that's just my recommendation.
if you still want to do that, try to Google it that's how i found this site, lol
300 Amps! How are you going to [safely] run 300 amps through an electrolytic cell?
If you try to do this for any extended period of time, you are going to boil your water away and ruin your electrodes.
The higher the current through the cell, the faster the Chlorate production, yes, but I would keep the current to a reasonable level if I were you.
There is an optimum temperature and current density (current per unit surface area of the electrodes) one might try to shoot for. Faster production is not always “better” in this sense.
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 31 ·
