Heat capacity problem-wher am i going wrong?
The discussion centers on a heat capacity problem involving a styrofoam cup containing 200g of water at 20 degrees Celsius and 100g of silver at 300 degrees Celsius. The user correctly calculated the equilibrium temperature as 28 degrees Celsius using the formula for heat transfer. However, they struggled with determining the specific heat capacity of an unknown substance added to the system, initially calculating it as 8600 J kg^-1 K^-1 instead of the correct value of 910 J kg^-1 K^-1. The error arose from misapplying the heat transfer equation in part b of the problem.
  • Understanding of heat transfer principles
  • Familiarity with specific heat capacity calculations
  • Knowledge of the formula for heat energy transfer
  • Basic algebra skills for solving equations
  • Review the concept of heat transfer and specific heat capacity
  • Practice problems involving multiple substances and heat exchange
  • Learn about the conservation of energy in thermal systems
  • Explore advanced topics such as calorimetry and its applications
Students studying thermodynamics, physics enthusiasts, and anyone looking to improve their understanding of heat transfer and specific heat capacity calculations.
debwaldy
Hi,so iv tried the following question and think my general methodology is correct but the final answer i am getting is wrong.ne ideas?
Question:a styrofoam cup contains 200g of water at 20 degrees celsius.What will be the equilibrium temp of the system after 100g of silver,initially at 300 degrees,has been added?you may assume that the heat capacity of the cup is negligible and that no heat is lost to the surroundings.
(b)a further 100g of an unknown substance,also at 300 degrees is now added to the system and the temperature rises by a further 26 degrees celsius
what is the specific heat capacity of the unknown substance?(the specific heat of water is 4180 Jkg^-1 K^-1 and that of silver 240 J kg^-1 K^-1)
so i got part a to work out correctly by saying:
heat energy lost by silver = heat energy gained by water
mass(silver).c(silver).(initial temp-final temp) =mass(water).c(water).(final temp-initial temp)
i.e. 0.1(240)(300-final temp)=0.2(4180)(final temp-20)
and found the equilibrium temp=28 degrees celsius,which i know is correct
its part b I am having trouble with:the correct answer is supposed to be 910 J kg^-1 K-1 but i keep getting 8600,by using the following,is it correct:
heat energy lost by unknown substance= heat energy gained by water and heat energy gained by silver
then:
mass(unknown).C(unknown).(26)=mass(water).c(water).(26) + mass(silver).c(silver).(26)
i.e. 0.1(c)(26) = 0.2(4180)(26)+0.1(240)(26)
=> c= 8600..which is wrong according to book?
any help wud be much appreciated
thanks :biggrin:
What is the temperature change for the unknown mass?[What is the final temperature for all three? = 28 + 26]
Using this, and your method, I get 908.9, which is close enough for me.
ok you that seems to make a lot more sense alright
thanks for the help:-p
