New Reply
Nonhomogeneous Boundary Value Problem
Share Thread
Dec2-06, 07:56 PM   #1
I've got a nonhomogeneous BVP I'm trying to solve. Both my book and my professor tend to focus on the really hard cases and completely skipp over the easier ones like this, so I'm not really sure how to solve it. It's the heat equation in a disk (polar coordinates) with no angle dependence.
[tex]\frac{\partial^2 u}{\partial r^2} + \frac{1}{r} \frac{\partial u}{\partial r} + Q = \frac{\partial u}{\partial t}[/tex]
Q is a constant.
0 < r < 1
t > 0
Subject To:
BC1) u(0, t) bounded
BC2) u(1, t) = 0
IC) u(r, 0) = 0
I start with the homogeneous (Q=0) case and separate variables to get ODE's for T(t) and R(r):
[tex]rR'' + R' + \lambda^2 r R = 0 [/tex]
[tex]
T' + \lambda^2 T = 0
[/tex]
Solving and applying the BC's, I get
[tex]
R_{n}(r)=c_{2}J_{0}(j_{n0}r), n=1,2,3,...[/tex]
[tex]
T_{n}(t)=c_{4}e^{-j_{n0}^2 t}, n=1,2,3,...[/tex]
Where [itex]j_{n0}[/itex] represents the nth zero of the [itex]J_{0}[/itex] Bessel function. Putting them together,
[tex]u_{hom}(r,t) = \sum \limits_{n=1} ^ {\infty} A_{n} e^{-j_{n0}^2 t} J_{0}(j_{n0}r) [/tex]
This is where I'm stuck at. In Previous problems, our inhomogeneous portion was a function of both space and time {Q(r,t)} and we would model both u(r,t) and Q(r,t) as infinite series of Bessel functions in r with time-dependent coefficients and substitute them back into the PDE, which would result in the sums and Bessel functions falling out, leaving an ODE we could solve to find the coefficients. That's not an option here since Q isn't a function of space OR time, so I really don't know where to go from here to get the partial portion of the solution.
Thanks in advance for your help,
Grogs
EDIT: Corrected homogeneous solution
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Dec3-06, 06:44 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Of course it's a "function of space and time", it's just a constant function! Any function of x and t can be written, as you say, as
[tex]A_{0} + \sum \limits_{n=1} ^ {\infty} A_{n} e^{-j_{n0}^2 t} J_{0}(j_{n0}r) [/tex]
What must An, for n> 0, be for that to be a constant? What is A0?
Dec3-06, 10:11 AM   #3
Halls,
The [itex]A_{n}[/itex]'s are zero in that case.
I should point that I goofed up when I wrote the homogeneous solution above. The n=0 case shouldn't be an eigenvalue (so no constants in the solution.) I must have been working on too many problems at once and gotten them mixed up. I edited my original post to reflect that correctly.
So where do I go from here? I've tried substituting the homogeneous solution back into the PDE, but nothing, including the sums, drops out so it's messier than the original PDE and doesn't seem to get me closer to a solution.
Thanks,
Grogs
Dec3-06, 12:41 PM   #4
Recognitions:
An= 0 for n>0 and obviously A0= C. Just include that when writing your equation as a sum of Bessel functions.
Dec3-06, 01:50 PM   #5
Are you saying I should model [itex]u_{hom}[/itex] and [itex]u_{part}[/itex] as:
[tex]u_{hom} = \sum \limits_{n=1} ^ {\infty} A_{n} \exp(-j_{n0}^2 t) J_{0}(j_{n0}r)[/tex]
(There is no n=0 solution for the homogeneous case)
and
[tex]u_{part} = c + \sum \limits_{n=1} ^ {\infty} A_{n} \exp(-j_{n0}^2 t) J_{0}(j_{n0}r) = c[/tex]
(there's only a constant for the partial case)
resulting in
[tex]u(r,t) = c + \sum \limits_{n=1} ^ {\infty} A_{n} \exp(-j_{n0}^2 t) J_{0}(j_{n0}r) [/tex]
How do I solve for c though? If I substitute u(r,t) back into the PDE c gets differentiated out. If I substitute just the partial solution [itex]u_{part}=c{/itex] in, I get Q = 0, which obviously can't be true.
Feb23-10, 05:48 AM   #6
I'm working on the exact same problem, any update?
Mar15-12, 11:46 PM   #7
we can write in the solution of a nonhomogenuos equation as
u(x)=integral(g(x.x1)*f(x)dx........where f(x) is the sourse term...if sourse term is zero.ie homogenous equation,what will be the solution?zero?what it means?homogenous equation has no solution?
then in the series form of greens function if lambda is one of the eigenvalue of the differential operator,den greens function become infinte.then we require that for the nonhomogemous eqn to have solution sourse term and eigenfunction shuold be orhogonal...can anyone explain why it should be orthogonal?
thanku
New Reply
Similar discussions for: Nonhomogeneous Boundary Value Problem
Thread Forum Replies
Boundary value problem Calculus & Beyond Homework 5
Riemann Boundary Value Problem Calculus 0
Boundary value problem Calculus & Beyond Homework 4
I found another boundary problem! Forum Feedback & Announcements 2
Boundary Value Problem Differential Equations 16
