Electrical seperation of hydrogen bonds
The discussion focuses on the theoretical application of electrical separation of hydrogen bonds in cellulose, specifically in the context of cutting paper. The user, Niko, explores whether applying a high voltage near cellulose could cleave molecular bonds, particularly hydrogen bonds formed by polar O-H groups. The response emphasizes that cellulose can undergo redox reactions, and suggests that acidic conditions may facilitate this process. It also highlights the complexity of applying voltage to paper due to its insulating properties, recommending further inquiry in engineering forums for detailed explanations.
  • Understanding of cellulose structure and properties
  • Knowledge of hydrogen bonding and molecular interactions
  • Familiarity with redox reactions in organic chemistry
  • Basic principles of electrical circuits and voltage application
  • Research the effects of acidic conditions on cellulose redox reactions
  • Investigate methods for applying voltage to insulating materials
  • Explore the energy requirements for breaking hydrogen bonds in cellulose
  • Learn about experimental techniques for molecular bond cleavage
Chemists, materials scientists, and engineers interested in molecular interactions and experimental techniques for manipulating cellulose and other polysaccharides.
nikolatesla20
Ok. It's been a long time since chemistry class.
Firstly, I'm investigating alternative techniques for cutting paper. Think, a normal sheet of computer printer paper. Disregard for the moment any chemical binders. Paper is close to 100% cellulose.
So, cellulose is a polysaccharide which "bristles" with polar O-H groups
(see http://antoine.frostburg.edu/chem/senese/101/consumer/faq/what-is-cellulose.shtml)
which will form hydrogen bonds with other O-H groups on other poly chains, bonding them together.
I know that removing the water is what joins the molecules initially. So adding water would most likely aid the separation, but of course it also messes up the paper.
What I'm curious about is, if one had enough electrical force (a high enough voltage), could one , for example, bring a highly positive plate near contact with the poly structure, and cause it to cleave? In other words, break the molecular bond at that point?
I'm not even sure how much "energy" is in one of these H-bonds, not to mention the energy involved in the C-O-H bond in between molecules. I'm assuming one would have to apply enough energy to overcome that energy.
I ask this question more out of a curiosity rather than a "commercial" application. I just thought it might be a good experiment. Perhaps of course the amount of energy required would simply burn the paper anyway :P
-niko
Chemistry news on Phys.org
You're asking a pretty specific theoretical question within a vague context, in relevance to an experimental setting. Cellulose does undergo redox reactions, to speed up this reaction, all you need to do is to place it in slightly more acidic conditions. As far as the "applying voltage to paper" goes, you would probably need a sophisticated technical method, since you would need to pass the charge throughout the insulating paper and also make a circuit, with the paper medium being an essential part of it. You may want to ask this question in one of the engineering forums to get a more detailed theoretical explanation.
15K
25K
15K
