Adapting to Extremes: The Versatility of Oceanic Microbes
  • Thread starter Thread starter Loren Booda
    Life
The discussion centers on the adaptability of oceanic microorganisms to extreme conditions, specifically their ability to thrive both at the ocean's surface and in its deepest trenches. It explores the physical and biochemical adjustments these microbes may undergo in response to varying pressure and salinity conditions.
  • Some participants propose that certain microorganisms can grow under both high pressure at ocean depths and lower pressure at the surface, indicating their adaptability.
  • One participant notes that barophilic microorganisms have enzymes that are structurally adapted to function under high pressure, which may allow them to also survive at lower pressures.
  • Another participant discusses the differences in membrane composition of barophiles, suggesting that specific proteins and fatty acids help maintain membrane flexibility under varying pressure conditions.
  • A participant raises a question regarding the osmotic balance of barophiles compared to surface microorganisms, indicating a potential area for further exploration.
  • One contributor mentions the thermohaline circulation system, highlighting that deep ocean waters are colder and saltier, which may require additional adaptations for microorganisms living in those environments.
  • Halophiles are introduced as organisms that can tolerate higher salinity, with some being facultative halophiles that can thrive in both high and low salinity conditions.
  • There is uncertainty regarding the specific mechanisms that allow microorganisms to adapt to both deep and surface conditions, with a call for microbiologists to contribute further insights.
Participants generally agree that microorganisms can adapt to extreme conditions, but multiple competing views remain regarding the specific mechanisms and adaptations involved. The discussion does not reach a consensus on the details of these adaptations.
Limitations include the lack of specific mechanisms described for how microorganisms adapt to surface conditions and the dependence on definitions of terms like barophiles and halophiles. There are also unresolved questions about osmotic balance and the effects of salinity on microbial life.
Loren Booda
Can certain microorganisms exist both on the ocean's surface and in its deepest trenches? How would they adjust between the physical extremes?
Biology news on Phys.org
According to this source, there are microbes that can grow under both conditions.
With reference to microbes in the ocean, those at the bottom are under very high atmospheric pressure (700-800 atm) (atm = atmospheres). At sea level we are at 1 atm. In addition to pressure, many of these organisms will experience colder temperatures at depth compared to the surface.
"Barophilic microorganisms grow best at high pressures although they still grow at 1 atm as well."
Evidently they are quite adaptable.
The same source I referenced, also describes some of the properties (biochemical and cytological) of microorganisms that favor hyperbarometic (high pressure) conditions.
What does pressure mean to a microbe? First of all, pressure tends to decrease the binding capacity of enzymes... The enzymes of extreme barophiles are often folded differently, in a way so that the pressure has less effect on them.
Membranes can also be affected by pressure. The cell wall outer membranes of barophiles tend to have a different protein composition compared to regular microbes. The porins (diffusion channels in membranes) of a barophile can be made up by a specific outer membrane protein. Its production is caused by a specific gene, which is switched on by high pressure.
The cytoplasmic membranes of barotolerant or barophilic organisms tend to have more of certain chemical compounds: (poly)unsaturated fatty acids and phosphatidylglycerol (a phospholipid). When this page was written, scientists thought that these compounds ensure the membrane’s flexibility at high pressure. It's possible that new research has lead to different conclusions ...
I am not aware of specific mechanisms for these microbes to adapt to life near the ocean's surface. In may be simply that their structure and physiology are not impeded at lower pressure.
Here's one physical analogy. Let's assume you change pressure conditions very slowly. If you made a balloon with a thick semipermeable membrane and fill it with water. Under high pressure it will not implode (membrane will not break), due to both the permeability and thickness of the membrane. At low pressure, the balloon will tend to inflate. However because the membrane is semipermeable, any pressure built up inside the membrane can dissipate, and again the balloon will not explode. It has the capability of maintaining its shape at both extreme conditions.
Ouabache,
Thanks for your excellent research.
I wonder whether the osmotic (saline) balance is generally different for barophiles than surface cells.
I am not a physical ocean scientist, so needed to read up on variation of salinity in the world oceans. In doing so, I learned of the thermohaline circulation system. Deep ocean waters are colder and have a higher salinity than warmer surface waters. See http://science.hq.nasa.gov/oceans/physical/SSS.html
Microbes living in the colder deep ocean would need a mechanism for coping with the higher salinity. Those capable of tolerating or thriving in this higher salt environment are called halophiles
"Halophiles concentrate solutes inside their cells to maintain osmotic balance with the external environment." A good diagram and description of this is at reference2
"Facultative" halophiles tolerate higher saline conditions but live quite comfortably under lower saline conditions too. It is likely that those microbes that can live at both the ocean depths and surface waters, are of this type. I don't know the specific mechanisms that allow them to cope under both conditions, perhaps some of our microbiologists can jump in here with their comments.
  • · Replies 114 ·
16K
