Materials and particle coupling
The discussion centers on the transmission of information through a 10-meter long stick when subjected to an actuator's push. It concludes that the speed of information transfer is limited by the material properties and relativistic principles. The participant suggests that the calculation involves constructing a stiffness tensor and understanding stress propagation within the material. Ultimately, even with a hypothetical 1 light-year long rod, the effect of a push would take over a year to propagate to the other end, demonstrating the constraints imposed by the speed of sound in materials.
  • Understanding of material properties and stiffness tensors
  • Knowledge of relativistic principles in physics
  • Familiarity with stress propagation in solid mechanics
  • Basic concepts of actuator mechanics and their effects on materials
  • Research the properties of materials and their stiffness tensors
  • Study the speed of sound in various materials and its implications
  • Learn about stress wave propagation in solid mechanics
  • Explore relativistic effects on information transfer in physical systems
Physicists, engineers, and materials scientists interested in the dynamics of material behavior under stress and the limits of information transfer in physical systems.
Ondra Spilka
Hi,
since I don't have exact knowledge about materials and particle coupling, I want to ask for result of simple experiment:
imagine you have very tough stick 10 meters long. Let's say the stick is fitted on firm steel table in sliding blocks. Table is equipped with actuator strong enough to shift the stick, which will push one end of the stick. On the second side of the stick in very small distance is detector, which will detect the stick contact.
So how fast will be information transferred from actuator to detector (let's say by push we transfer 1/2 of a bit)? Of course it depends on velocity of actuator shift, distance between detector and second side of stick. This is known.
But how fast the change of space coordinates on one side of the stick will appear on the second side?
How fast inbetween joins of atoms can react? Are they also limited by relativity limits?
Thanks for answer.
P.S.
try length of te stick 10meters, distance between detector and stick 1um, actuator velocity 30m/s.
Hmm i think the actual calculation would get rather involved because you would have to know the actual properties of the material to construct some kind of stiffness tensor then go on constructing a stress on that whole thing and whatever there may come better ask an engineer :)
But from a general point of view the whole thing is surely limited by relativistic principles.
Would be the same thing if you hand some kind of enormously long rod of steel say 1 LY long an you push it on one side, the effect would still take more than one year to propagate to the other side, maybe as some kind of wave in the material i guess.
  • · Replies 40 ·
