Find a matrix that diagonalizes the matrix A
  • Thread starter Thread starter suspenc3
    Matrix
The discussion revolves around finding a matrix that diagonalizes a given matrix A, focusing on the identification of eigenvalues and eigenvectors. The problem is situated within the context of linear algebra.
  • Participants discuss the process of finding eigenvalues and eigenvectors, with some expressing confusion about the relationship between the eigenvector and the characteristic equation. Questions arise regarding the necessity of multiple eigenvectors for diagonalization and the implications of the eigenvector equation.
Participants are actively engaging with the concepts, with some providing clarifications about the eigenvector definition and its derivation from the characteristic equation. There is a recognition of the need for further exploration of the eigenvector corresponding to the eigenvalue.
There is mention of potential misunderstandings regarding the number of eigenvectors required for diagonalization and the specific calculations leading to the eigenvector. The discussion reflects a mix of attempts to clarify definitions and explore the implications of the mathematical relationships involved.
suspenc3
This could be a dumb question..but here goes:
Im trying to find a matrix that diagonalizes the matrix A. If I find my eigenvalues and then proceed to get my eigenvectors...after row reducing I get 1, 1, 0, 0.(2X2 matrix, two 1's on top).what is the eigenvector?
In this case you have a single eigenvector of value (1,0) and I say you would have made a mistake somewhere in the question since n eigenvectors are required to diagonalise an nxn matrix.
I got two eigenvectors, i just didnt know what to do with:[tex]\left(\begin{array}{cc}1&1\\0&0\end{array}\right)[/tex]
Apologies, I misread your post. To find your eigenvector you need the following to be true;
[tex]\left(\begin{array}{cc}1&1\\0&0\end{array}\right)\cdot \left(\begin{array}{c}x\\y\end{array}\right) = 0[/tex]
Do you know why?
P.S. I assume you have obtained the above matrix by applying the Characteristic equation, namely [itex]\det(A-\lambda\cdot I) = 0[/itex]
Yes that's how I got it. And I am not sure why they must equal 0.
No one cares that your an english major..have you pointed that out in every post?
Okay, so you've got your matrix A, solved the characteristic equation and obtained your eigenvalues. You've then applied your eigenvalues to your characteristic equation of A and obtained the following;
for [itex]\lambda =1[/itex]
[tex]( A - (1)I ) = \left(\begin{array}{cc}1&1\\0&0\end{array}\right)[/tex]
Now the definition of an eigenvector (v) of matrix A is a non-zero vector such that [itex]A\underline{v}=\lambda\underline{v}[/itex], where [itex]\lambda[/itex] is your eigenvalue. We can rewrite the above relationship as
[tex]A\underline{v} - \lambda\underline{v} = 0[/tex]
Using the fact the [itex]I\underline{v} = \underline{v}[/itex] (I being the Identity matrix) we obatin;
[tex]A\underline{v} - \lambda I \underline{v} = 0[/tex]
[tex]\therefore \; (A-\lambda I)\underline{v} = 0[/tex]
Does that make sense? In R2 (as in your case);
[tex]\underline{v} = \left(\begin{array}{c}x\\y\end{array}\right)[/tex]
which is where the equation I posted comes from. In fact the characteristic equation follows directly from this relationship.
ohhh, Ok, that makes sense,
Thanks
Thanks
No problem, so what do you obtain for your eigenvector corresponding to [itex]\lambda=1[/itex]?
