How Does Momentum and Kinetic Energy Change in a Series of Elastic Collisions?
  • Thread starter Thread starter PremedBeauty
    Collision
The discussion revolves around the dynamics of a series of elastic collisions involving three blocks with varying masses. The original poster presents a scenario where block 1 collides with block 2, which then collides with block 3, prompting questions about the speeds, kinetic energies, and momenta of the blocks before and after the collisions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the conservation of momentum and kinetic energy in elastic collisions. The original poster attempts to calculate the speed of block 3 and compare its kinetic energy and momentum to those of block 1. Some participants question the treatment of collisions as elastic versus inelastic and suggest using specific relationships for elastic collisions.
There is ongoing exploration of the principles governing elastic collisions, with participants providing insights on conservation laws and equations relevant to the problem. Some guidance has been offered regarding the relationships between velocities before and after collisions, but there is no explicit consensus on the approach to take.
Participants express uncertainty about identifying initial and final velocities, as well as the implications of the elastic nature of the collisions. The original poster's calculations and assumptions are under scrutiny, and there is a need for clarification on the definitions and relationships involved in elastic collisions.
PremedBeauty
block 1 of mass m1 slides along an x-axis on a frictionless floor with speed of v1i=4.00 m/s. Then it undergoes a one dimensional elastic collision with stationary block 2 of mass m2=.500m1. Next, block 2 undergoes a one dimensional elastic collision with stationary block 3 of mass m3=.500m2. (a) What then is the speed of block 3? Are (b) the speed, the kinetic energy, and (d) the momentum of block 3 greater than, less than, or the same as the initial values for block1?
The lines, the "x" and numbers are kinda croocked, sorry.
a)We use the principle of conservation of momentum here.
Initially momentum is (m1)(4)
After collision with m2, it will be (v)(m1+0.5m1) = (v)(1.5m1)
After collision with m3, it will be (u)(1.5m1+0.25m1) = (u)(1.75m1)
this is bevause m3 = 0.5m2 = 0.5(0.5m1) = 0.25m1.
They must be equal so
(m1)(4) = (u)(1.75m1)
u = 2.3m/s roughly!
(b) Calculate the KE of m3. It is 1/2(2.3)(0.25m1)2
The KE of m1 is 1/2(m1)(42)
See which one is greater!
(d) They are asking the momentum of m3 and not total momentum. Right?This will be (0.25m1)(2.3) where as that of m1 is (m1)(4) so of course that of m1 is greater
It appears that you are treating the collisions as inelastic collisions. The problem says they are elastic collisions. Both momentum and kinetic energy are conserved. For such collisions there is a velocity difference relationship you might want to use.
Oh, How would you do it if it were elastic?
By definition, in an elastic collision, kinetic energy is conserved. Calculate the total kinetic energy before and after collision.
How do I know which numbers are before and after? Can you show me some how?
The momentum conservation equations apply to each collision
m1*v1i = m1*4.00 m/s <== total momentum
m1*v1i = m1*v1f + m2*v2b <== first collision (b subscropt for between collisions
m2*v2b = m2*v2f + m3*v3f <== second collision
If you combine these equations, you have
m1*v1i = m1*v1f + m2*v2f + m3*v3f
The total momentum after both collisions have occurred is the same as the initial total momentum. But this is not enough for you to find the velocities. You need to apply conservation of kinetic energy to each collision. Kinetic energy involves the squares of the velocities, so the algebra can get bit messy. But it is not too difficult to do the calculation algebraically one time to find a relationship between the differences between the velocities of the two masses before and after the collision. Once you have this relationship, you can use it in all elastic collsion problems without dealing with the squares in the energy equation. If your textbeook does not have this equation, see if you can derive it yourself. If you get stuck, look here towrd the bottom of the page.
http://www.astrophysik.uni-kiel.de/~hhaertel/MECHANICS/Mathe/mathe.html
For any 1-dimensional two-mass elastic collision
M1*V1i + M2*V2i = M1*V1f + M2*V2f
M1*V1i² + M2*V2i² = M1*V1f² + M2*V2f²
Solve for V1f - V2f in terms of V1i - V2i
Hello,
I'm sorry, I'm still not really following. I still have to find the momentum of block B and state is the kinetic, the speeed of block 3 greater than, less than, or same as initial.
PremedBeauty said:
Hello,
For any 1-dimensional two-mass elastic collision:
M1*V1i + M2*V2i = M1*V1f + M2*V2f <== Rearrange this momentum equation
M1*V1i - M1*V1f = M2*V2f - M2*V2i <== Factor the Ms
M1(V1i - V1f) = M2(V2f - V2i)
M1*V1i² + M2*V2i² = M1*V1f² + M2*V2f² <== Rearrange this energy equation
M1*V1i² - M1*V1f² = M2*V2f² - M2*V2i² <== Factor the Ms
M1(V1i² - V1f²) = M2(V2f² - V2i²) <== Factor the differences of squares
M1(V1i - V1f)(V1i + V1f) = M2(V2f - V2i)(V2f - V2i)
Divide this last equation by the rearranged factored momentum equation above to get
(V1i + V1f) = (V2f + V2i)
This is usually rearranged and written as
(V1i - V2i) = -(V1f -V2f)
This equation is valid for any elastic collision of two objects in one dimension. Use it with the conservation of momentum equation for each collision in your problem. At least give this a try an post your results.
  • · Replies 16 ·
  • · Replies 22 ·
