Solving Z Transform of Difference Equation: x(n+2)-0.3679x(n+1)+0.3679x(n)
  • Thread starter Thread starter angel23
    Transform
The discussion revolves around solving a difference equation using the Z-transform. The equation involves an input function defined by specific values at discrete points, and participants are attempting to determine the output function x(n) based on this input.
  • Homework-related
  • One participant presents the difference equation and attempts to apply the Z-transform, expressing confusion about how to proceed with the solution.
  • Another participant points out that the problem lacks specified initial conditions, suggesting that this makes the problem unsolvable in its current form.
  • A third participant asserts that the question provided is complete and implies that the input function is not a standard step function, indicating that the specific values of u(n) must be utilized to construct the input signal for analysis.
There is disagreement regarding the completeness of the problem statement, with one participant asserting it is complete while another insists that initial conditions are necessary for a solution.
Participants express uncertainty about how to incorporate the specific values of the input function u(n) into their solution process. The discussion reflects a reliance on the definitions of the input function and the initial conditions, which remain unresolved.
angel23
consider the difference equation
x(n+2)-0.3679x(n+1)+0.3679x(n)=0.3679u(n+1)+u(n)
where u(n) is the input and given by
u(n)=0 n<0
u(0)=1
u(1)=0.2142
u(2)=-0.2142
u(n)=0 n=3,4,5...
determine the output x(n)
let A=0.3679 and B=0.3642
i took z transform for both sides so it became.
z^2 x(z)-z^2x(0)-zx(1)-A[zx(z)-zx(0)]+Ax(z)=A[zu(z)-zu(0)]+Bu(z)
x(z)[z^2-Az+A]+x(0)[Az-z^2]-zx(1)=A[zu(z)-zu(0)]+Bu(z)
x(z)[z^2-Az+A]=A[zu(z)-zu(0)]+Bu(z)-x(0)[Az-z^2]+zx(1)
then what can i do?
also how can i make use of u(1)=0.2142
u(2)=-0.2142
i am too confused and need help.
To solve the problem, you need to specify some initial conditions. As it stands, it's unsolvable.
this is the full question given to me to solve and i am sure it is complete.
late reply ,, have you known the correct solution ?
the key that the input is not a step function , u have to use the u(0) , u(1) ... etc to draw the input and find expression to it .
