| Thread Closed |
Conductive Heat Loss from a House |
Share Thread | Thread Tools |
| Dec9-06, 08:24 PM | #1 |
assuming that the temperature inside is T_in = 20 C and the temperature outside is T_out = 0 C. The walls and uppermost ceiling of a typical house are supported by 2*6-inch wooden beams (k_wood = 0.12 W/m /K) with fiberglass insulation (k_ins = 0.04 W/m /K) in between. The true depth of the beams is actually 5 *5/8 inches, but we will take the thickness of the walls and ceiling to be L_wall = 18 cm to allow for the interior and exterior covering. Assume that the house is a cube of length L = 9.0 m on a side. Assume that the roof has very high conductivity, so that the air in the attic is at the same temperature as the outside air. Ignore heat loss through the ground. 2. Relevant equations The first step is to calculate k_eff, the effective thermal conductivity of the wall (or ceiling), allowing for the fact that the 2*6 beams are actually only 1*5/8 wide and are spaced 16 inches center to center. Express k_eff numerically to two significant figures in watts per kelvin per meter. |
| Dec10-06, 10:54 AM | #2 |
Recognitions:
The numbers that you have for k_wood and k_ins have units proportional to 1/m, but there are two spatial quantities in k. One is the thickness and one is the area. You need to find the definition for k and figure out how much area is associated with each of the materials in your problem to come up with the k_eff.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Conductive Heat Loss from a House
| Electrically non-conductive thermally conductive material | Materials & Chemical Engineering | 26 | ||
| House Color and Heat | Classical Physics | 8 | ||
| heat loss in a house | Introductory Physics Homework | 1 | ||
| Rate of heat loss? Speed of heat. | Classical Physics | 28 | ||
| heat loss | Introductory Physics Homework | 3 | ||
