| Thread Closed |
among Simple harmonic oscillation, simple pendulum and physical pendulum |
Share Thread |
| Dec9-06, 11:55 PM | #1 |
What is the similarity between Simple Harmonic Oscillation(SHO), simple pendulum and a physical pendulum? I never understood it. Like whats the physical significance of SHO, or the energy and momentum change in oscillating motion?
| Dec10-06, 01:01 AM | #2 |
I dont understand your question. Simple Harmonic Motion is just that, simple-harmonic-motion.
In this idealization, no energy is lost to the system; therefore, it is converted from all potential energy at the top of the arc to all kinetic energy at the bottom of the arc. This is known as Rayleigh's energy method. |
| Dec10-06, 08:05 AM | #3 |
Simple harmonic oscillation is a system described by [tex]\ddot{x}=-\omega^2 x[/tex] where [itex]\omega[/itex] is some constant, and [itex]x[/itex] is usually a displacement variable. We can solve this equation in general, very easily. An example of this is the spring-mass oscillator. Simple pendulum Another example is the simple pendulum, where [itex]x=\theta[/itex] the angular displacement, and [itex]\omega^2 = g/l[/itex]. Physical pendulum As for the physical pendulum, if we are careful, we find that it is not a true simple harmonic oscillator; instead it obeys the following equation: [tex]\ddot{x}=-\omega^2 \sin(x).[/tex] In the case of small displacements: [tex]\lim_{x\rightarrow 0}\sin(x)=x[/tex] and we find that in this case, the physical pendulum is well approximated by the simple pendulum. This is useful since the SHO equation is solved much more easily than the equation for the physical pendulum. |
| Dec10-06, 09:32 AM | #4 |
Not really, masudr.
The only difference between the "simple pendulum" and the "physical pendulum" is the mass distribution; the simple pendulum consists of a massless rod ending in a bob with mass. An example of a "physical pendulum" would be a rod of uniform density. Note that this difference in mass distribution makes for different moments of inertiae, and therefore different periods of the pendulae. Simple harmonic motion is not present in either case, but for small angular displacements, that approximation is justified. |
| Dec10-06, 06:06 PM | #5 |
thanks alot, also does the period have any m dependence in the simple pendulum? No right since its a masless rod. Also under what condition does the theoretical formula hold for the simple pendulum, would it be only for larger angles and amplitudes?
Also there is a mass dependence in the physical pendulum right and does the theoretical formula hold for small angular displacements? |
| Dec10-06, 06:36 PM | #6 |
| Dec10-06, 07:44 PM | #7 |
can someone answer this please
does the period have any m dependence in the simple pendulum? No right since its a masless rod. Also under what condition does the theoretical formula hold for the simple pendulum, would it be only for larger angles and amplitudes? Also there is a mass dependence in the physical pendulum right and does the theoretical formula hold for small angular displacements? |
| Dec11-06, 12:15 AM | #8 |
pawana,
do you go to stonybrook? these questions sound reeeally familiar.. |
| Dec11-06, 02:02 AM | #9 |
| Dec11-06, 09:16 AM | #10 |
Near any stable equilibrium, the 2nd degree Taylor expansion of the potential is the simple harmonic oscillator, so any oscillation near a stable equilbrium can be approximated by simple harmonic motion.
And also, the differential equation is linear and very easily solved. |
| Dec11-06, 09:56 AM | #11 |
Recognitions:
One can (and people have) engaged in debate over whether the gravitational mass in GMm/rē and the inertial mass in F = ma are the same thing, but for all the situations you are likely to encounter, they can be safely treated as being the same. The mass dependence neatly drops out for the simple pendulum if you treat the mass as a point object that has no rotation. If the mass is distributed, then the distribution of the mass comes into play. Even a small spherical bob would have some rotation, so you could treat it as a physical pendulum and find a slight difference in the calculated period compared to the simple pendulum. However, if you look at the equation for the period of the physical pendulum it involves the ratio I/m and I is always proportional to the mass of an object. So the mass divides out for the physical pendulum as well, but the factors in I that depend on the shape of the object do not drop out http://hyperphysics.phy-astr.gsu.edu/hbase/pendp.html |
| Thread Closed |
Similar discussions for: among Simple harmonic oscillation, simple pendulum and physical pendulum
| Simple Harmonic Motion of a pendulum | Introductory Physics Homework | 6 | ||
| Simple Harmonic Motion & Pendulum Problems! Need HELP! | Introductory Physics Homework | 6 | ||
| Simple Harmonic Motion of a Pendulum | Introductory Physics Homework | 4 | ||
| Simple Pendulum Motion and Physical Pendulum | Introductory Physics Homework | 6 | ||
| 3rd Harmonic Content for a Simple Pendulum? | Classical Physics | 8 | ||
